Author Topic: how to identify entities with in a block??  (Read 1589 times)
rainier
« on: January 14, 2008, 10:08:50 PM »
guys! please help me in my lisp routine...
i have a structure on what i mean...
block1
   |--> block 2    <-- how to get this information of block on my selection in lisp routine....
   |         |--> circle 2
   |         |--> line 2
   |--> line 1
   |--> circle 1
please help!!!  thanks..
Re: how to identify entities with in a block??
« Reply #1 on: January 14, 2008, 11:21:16 PM »
More info needed !
Is the block named ?
Is the parent block named ?
Can you post a sample ?
What Info do you need ?
How do you select it ?
.. and probably a few other things ..
rainier
« Reply #2 on: January 15, 2008, 01:58:19 AM »
hi kerry,
i am making a lisp routine that will add and remove entity or entities from the parent block especially..
especially block with a parent block..  :-(
i dont know how... please help me..  :-(
thanks
« Reply #3 on: January 15, 2008, 10:57:50 AM »
Guest
« Reply #4 on: January 15, 2008, 12:05:57 PM »
The Express tools have something that might help you.  It's in Blocks --> List Xref/Block Properties
