Author Topic: Microsoft Parallel Extensions to .NET (CTP)  (Read 2384 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Microsoft Parallel Extensions to .NET (CTP)
« Reply #1 on: December 08, 2007, 02:52:33 AM »
aahhhhhhhhhhh, its not fair!
using System;
using System.Linq;
using System.IO;
using System.Threading;
using AcAp = Autodesk.AutoCAD.ApplicationServices;
using AcEd = Autodesk.AutoCAD.EditorInput;
using AcGe = Autodesk.AutoCAD.Geometry;
using AcRx = Autodesk.AutoCAD.Runtime;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
using AcWd = Autodesk.AutoCAD.Windows;
[assembly: CommandClass(typeof(search.Commands))]
namespace search
  public static class Commands
    [CommandMethod("doit")]
    public static void doit()
      Editor ed = AcAp.Application.DocumentManager.MdiActiveDocument.Editor;
      List<string> strlist = new List<string>();
      PromptStringOptions pso1 = new PromptStringOptions("Enter path");
      pso1.AllowSpaces = true;
      PromptResult prs1 = ed.GetString(pso1);
      if (prs1.Status != PromptStatus.OK)
        return;
      PromptStringOptions pso2 = new PromptStringOptions("Enter String to search");
      pso2.AllowSpaces = true;
      PromptResult prs2 = ed.GetString(pso2);
      if (prs2.Status != PromptStatus.OK)
        return;
      string[] strarray = GetDwgFilesFromDir(prs1.StringResult);
      try
        Parallel.For(0, strarray.Length, delegate(int i) //<----------------------------
          using (Database db = new Database(false, true))
            db.ReadDwgFile(strarray[i], FileShare.Read, true, "");
            AcDb.TransactionManager Tm = db.TransactionManager;
            using (Transaction tr = Tm.StartTransaction())
              BlockTable tb = (BlockTable)tr.GetObject
                           (db.BlockTableId, OpenMode.ForRead, false);
              BlockTableRecord btr = (BlockTableRecord)tr.GetObject
                           (tb[BlockTableRecord.ModelSpace], OpenMode.ForRead, false);
              foreach (ObjectId id in btr)
                DBObject dboject = (tr.GetObject(id, OpenMode.ForRead));
                if (dboject is MText)
                  MText mt = (MText)dboject;
                  if (mt.Text.ToUpper().Contains(prs2.StringResult.ToUpper()))
                    strlist.Add(strarray[i] + " contains string: " + prs2.StringResult);
            db.CloseInput(true);
        foreach (string str in strlist)
          ed.WriteMessage("\n" + str);
      catch (System.Exception ex)
        ed.WriteMessage(ex.Message);
    //this function needs .NET 3.5 to run/compile
    public static string[] GetDwgFilesFromDir(string path)
      var MyList = from f in Directory.GetFiles((path))
                   where Path.GetFileName(f).ToUpper().Contains(".DWG")
                   select f;
      return MyList.ToArray();
« Last Edit: December 08, 2007, 03:02:45 AM by Daniel »
« Reply #2 on: December 08, 2007, 03:22:58 AM »
Looks like you've had a good Saturday afternoon Daniel :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: December 08, 2007, 03:35:12 AM »
Yes yes, I am now able to throw exceptions in parallel  :lol:
