Author Topic: can you check my code about area / length filtering  (Read 4518 times)
dussla
« on: November 05, 2007, 08:07:51 PM »
i made some code
that code fucnction is  to filtering  same area /  same length objects
but that is not working correctly
can you test and modify ~~
Re: can you check my code about area / length filtering
« Reply #1 on: November 05, 2007, 10:00:55 PM »
Try something like this.
Note that this is just an example, not finished code.
;;  CAB 11.05.2007
;;  Get a selection set of thawed objects with matching area and layer in current space
(defun AreaMatch (/ ent obj Area2match lst ss ss2)
  (while
    (not
      (and
        (or (setq ent (car (entsel "\nSelect object to match area & layer.")))
            (prompt "\nMissed, try again."))
        (setq obj (vlax-ename->vla-object ent))
        (or (vlax-property-available-p obj 'area)
            (prompt "\nNo Area for that object, try again."))
  (setq Area2match (vla-get-area obj)
        ss2  (ssadd)
  (if (setq ss (ssget "All" (list (cons 8 (vla-get-layer obj))
                                  (cons 410 (getvar "ctab")))))
      (setq lst (mapcar 'vlax-ename->vla-object (mapcar 'cadr (ssnamex ss))))
      (mapcar
        '(lambda (x)
           (if (and (vlax-property-available-p x 'area)
                    (equal Area2match (vla-get-area x) 0.001))
             (ssadd (vlax-vla-object->ename x) ss2)
        lst
  (if (and ss (not(zerop(sslength ss2))))
    ss2
(defun c:test( / ss)
  (if (setq ss (AreaMatch))
    (command "_.move" ss "")
dussla
« Reply #2 on: November 05, 2007, 10:12:35 PM »
thank you answer
i will test soon
if i want to filter  same perimeter (= length ) about entry ?
sorry  i dont know obejct arx programing well
« Reply #3 on: November 06, 2007, 03:38:11 PM »
Try this for length:
;;  CAB 11.06.2007
;;  Get a selection set of thawed objects in current space with matching length a
;;  Option to match layer too
;;  Note that the object my not have a length property but may still have a length
;;  via the vlax-curve function
;;  Highlights the selected items & returns the selection set
(defun c:lSel (/ fuzz ent obj layFilter Length2match lst ss ss2 len)
  (setq fuzz  0.001)
  (while
    (not
      (and
        (or (setq ent (car (entsel "\nSelect object to match length & layer.")))
        (or (not (vl-catch-all-error-p
                   (vl-catch-all-apply
                      'vlax-curve-getdistatparam (list obj 0.1))))
             (prompt "\nNo Length for that object, try again."))
  (initget "Yes No")
  (if (equal (getkword "\nMatch layer too? [Yes/No]<Yes>: ") "No")
     (setq layFilter '(8 . "*"))
     (setq layFilter (cons 8 (vla-get-layer obj)))
  (setq Length2match (vlax-curve-getdistatparam  obj
                       (vlax-curve-getendparam obj))
        ss2  (ssadd)
  (prompt (strcat "\nLength to matcn = " (rtos Length2match)))
  (prompt "\nSelect objects or ENTER for All objects in this space.")
  (if (or (setq ss (ssget (list layFilter (cons 410 (getvar "ctab")))))
          (setq ss (ssget "_All" (list layFilter (cons 410 (getvar "ctab"))))))
                        (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))))
      (mapcar
        '(lambda (x)
           (if (and
                        (setq len (vl-catch-all-apply
                                         (list x (vlax-curve-getendparam x))))))
                 (equal Length2match len fuzz))
        lst
  (sssetfirst)
  (print)
    (cadr(sssetfirst nil ss2))
<edit: bug fixed>
« Last Edit: November 08, 2007, 09:11:57 AM by CAB »
« Reply #4 on: November 06, 2007, 08:26:58 PM »
Here is one for area that is a more polished version.
;;  Sel by Area.lsp
;;  CAB 11.05.2007
;;  Get a selection set of thawed objects in current space with matching area
(defun c:aSel (/ fuzz ent obj layFilter Area2match lst ss ss2)
  (setq fuzz  0.001)
  (while
    (not
      (and
  (initget "Yes No")
        ss2  (ssadd)
      (mapcar
        '(lambda (x)
                    (equal Area2match (vla-get-area x) fuzz))
        lst
  (sssetfirst)
  (print)
« Reply #5 on: November 06, 2007, 08:29:35 PM »
And while I'm at it one for object type.
;;  Sel by Type.lsp
;;  CAB 11.06.2007
;;  Get a selection set of thawed objects in current space with matching type
(defun c:oSel (/ fuzz ent obj layFilter Area2match lst ss ss2)
  (setq fuzz  0.001)
  (while
    (not
      (and
        (or (setq ent (car (entsel "\nSelect object to match object type & layer.")))
              typ (cdr(assoc 0 (entget ent))))
        (or (not (vl-position typ '("")))
            (prompt "\nObject type not supported, try again."))
  (initget "Yes No")
  (setq ss2 (ssadd))
  (or (setq ss (ssget (list layFilter (cons 0 typ)(cons 410 (getvar "ctab")))))
      (setq ss (ssget "_All" (list layFilter (cons 0 typ)(cons 410 (getvar "ctab"))))))
  (sssetfirst)
  (print)
  (if (and ss (not(zerop(sslength ss))))
    (cadr(sssetfirst nil ss))
dussla
« Reply #6 on: November 07, 2007, 08:18:07 PM »
thank you good reply
your code is perpect ~~~
thank you again
« Reply #7 on: November 07, 2007, 08:43:08 PM »
You are welcome. :-)
Jan ter Aij
« Reply #8 on: November 08, 2007, 09:01:32 AM »
Dear CAB,
Why gives the program lSel the following error message:
Error: bad argument type: lentityp (0 (162.023 88.2897 0.0))
Regards Jan.
« Reply #9 on: November 08, 2007, 09:13:45 AM »
Oh shoot! :x
I updated part of that routine & didn't test it.
Copy it again as I updated the code.
PS Welcome to TheSwamp :-)
Jan ter Aij
« Reply #10 on: November 09, 2007, 09:22:34 AM »
Oh shoot! :x
Dear CAB,
Thank You.
Regards Jan.
