Author Topic: terrain model explorer won't come up  (Read 2826 times)
drizzt
« on: October 25, 2007, 10:50:29 AM »
I just started using LDT 2007 at a new company. When I open a file they previously created and try to open the Terrain model explorer, I get:
C:\Autodesk\Autodesk Land Desktop 2007\aeccapp50.arx cannot find a dll or other
file that it needs.
; error: ARXLOAD failed
Command:  Unknown command "LDD".  Press F1 for help.
Does this mean there is a bad install?
I know there are surfaces for this project, I saw them on another pc.
Guest
Re: terrain model explorer won't come up
« Reply #1 on: October 25, 2007, 10:51:47 AM »
Pretty much!  You're obviously missing a file or two (or 3 or 4 or...).
sinc
« Reply #2 on: October 25, 2007, 11:02:01 AM »
It *could* be that you are missing paths from your Support path.
But it does sound a lot like a bad install...
« Reply #3 on: October 25, 2007, 11:03:51 AM »
this suggest a repair install is in order, or copy missing file from other machine and try again....
Guest
« Reply #4 on: October 25, 2007, 11:07:47 AM »
...or copy missing file from other machine and try again....
We've done that before... compared the folders of a good install vs. those of a bad install and noticed that there were less files in the bad install and simply copied them and *poof* all was right with the world again.
drizzt
« Reply #5 on: October 25, 2007, 11:19:00 AM »
I am going to try the re-install and see what happens. Thanks for the fast responses!
