Author Topic: How do you terminate an ACAD command?  (Read 5760 times)
gmyroup
« on: October 18, 2007, 08:05:41 AM »
Good morning
What is your preferred method for terminating an ACAD command?
Jerry
hendie
Re: How do you terminate an ACAD command?
« Reply #1 on: October 18, 2007, 08:16:51 AM »
you missed right click only which is what I use
Guest
« Reply #2 on: October 18, 2007, 08:22:50 AM »
I actually use all of the above (except I have my right-click set up as an <ENTER> only) depending on the mood/command I'm in.
Josh Nieman
« Reply #3 on: October 18, 2007, 08:25:35 AM »
Ditto Matt, though ESC is most common, so I voted for that.
I have my RightClick menus set like Hendie.  So depending on the command and what it's expecting for entry, I may simply right click.
M-dub
« Reply #4 on: October 18, 2007, 08:29:02 AM »
All of the above.  Right click is Enter Only, too.
Guest
« Reply #5 on: October 18, 2007, 08:31:52 AM »
Almost forgot the occasional "three-finger-salute" when ESC won't work.  :-)
M-dub
« Reply #6 on: October 18, 2007, 08:32:52 AM »
CTRL + Alt + Delete ? :)
Guest
« Reply #7 on: October 18, 2007, 08:36:14 AM »
BINGO!
gmyroup
« Reply #8 on: October 18, 2007, 11:05:50 AM »
Thanks for your input everyone.  How do you set the right-click so it acts as the enter key?
Jerry
Josh Nieman
« Reply #9 on: October 18, 2007, 11:08:02 AM »
Jerry
Tools > Options > User-Preferences > Right-Click Customization
craigr
« Reply #10 on: October 18, 2007, 11:13:34 AM »
My mouse has 2 extra buttons, one each on each side.
I have the Right one programmed as ESC.
It makes it much easier to terminate a command when ENTER is not appropriate.
craigr
« Reply #11 on: October 18, 2007, 11:15:02 AM »
I prefer to use the right click, but with some of the commands in electrical (or the customization my company did) it doesn't let you enter out of a command, so I have to use esc.  I voted for right click though, as that is my preferred way to exit a command.
gmyroup
« Reply #12 on: October 18, 2007, 01:14:34 PM »
Thanks Josh
deegeecees
« Reply #13 on: October 18, 2007, 03:00:55 PM »
I use the Awnold method...
OK, bad joke.
Right Click.
Dinosaur
« Reply #14 on: October 18, 2007, 08:51:58 PM »
And for those "special" Civil 3D moments when nothing else will do . . . the old end process button in task manager - it still may take 3 or more tries before kicking in but at least I don't have to resort to the power button since 2007 came out.
