Author Topic: list question  (Read 5841 times)
Joe Burke
list question
« on: October 07, 2007, 10:49:25 AM »
(setq lst '((24.0 305.333 17.3333) (1.2 15.2667 0.866667)
            (4.8 61.0667 3.46667) (12.0 152.667 8.66667))
Notice, the second and third values in each sublist are proportional to the first value in each sublist.
I'm trying to write a test function which returns T if that's the case for all items within the list.
So far, I can't see the logic behind it. But I'm fairly sure it's there somewhere.
Re: list question
« Reply #1 on: October 07, 2007, 11:10:52 AM »
Maybe this?
(defun c:test ()
  (vl-every '(lambda (x / y z)
               (and
                 (if y
                   (equal y (/ (cadr x) (car x)) 1e-4)
                   (setq y (/ (cadr x) (car x)))
                 (if z
                   (equal z (/ (caddr x) (car x)) 1e-4)
                   (setq z (/ (caddr x) (car x)))
            lst
Here is another variation:
(defun c:test (/ r1 r2)
  (setq r1 (/ (cadar lst) (caar lst)))
  (setq r2 (/ (caddar lst) (caar lst)))
  (vl-every '(lambda (x)
               (and (equal r1 (/ (cadr x) (car x)) 1e-4)
                    (equal r2 (/ (caddr x) (car x)) 1e-4)
            (cdr lst)
« Last Edit: October 07, 2007, 07:06:46 PM by CAB »
LE
Re: list question
« Reply #2 on: October 07, 2007, 12:10:53 PM »
Hola Jose;
See if this does some job... if not it is ok.... :)
(defun are-proportional  (lst / res)
  (setq res
         (apply
           'append
           (mapcar
             (function
               (lambda (sub)
                 (mapcar
                   (function (lambda (x) (setq i (car sub)) (- (/ x i) (fix (/ x i)))))
                   (cdr sub))))
             lst)))
  (vl-every (function (lambda (i) (equal (car res) i 0.0001))) (cdr res)))
_$ (are-proportional
    (12.0 152.667 8.66667)))
T
  '((24.0 305.3246 17.3333)
    (1.2 15.2967 0.866667)
nil
The same function, without one of the vars...
  (setq res
         (apply
           'append
           (mapcar
             (function
               (lambda (sub)
                 (mapcar (function (lambda (x) (- (/ x (car sub)) (fix (/ x (car sub))))))
                         (cdr sub))))
             lst)))
« Last Edit: October 07, 2007, 12:15:41 PM by Luis Esquivel »
FengK
Re: list question
« Reply #3 on: October 07, 2007, 04:15:22 PM »
this is probably ugly.
(setq lst1 '((24.0 305.333 17.3333)
(setq lst2 (mapcar (function (lambda (l)
                (list (/ (car l) (cadr l))
                 (/ (cadr l) (caddr l))
         lst1
(setq lst3 (mapcar 'car lst2)
      lst4 (mapcar 'cadr lst2)
(setq fuzz 1e-4)
(and (equal (apply 'max lst3) (apply 'min lst3) fuzz)
     (equal (apply 'max lst4) (apply 'min lst4) fuzz)
gile
  • Marseille, France
Re: list question
« Reply #4 on: October 07, 2007, 04:44:03 PM »
Hi
Here's my way
(defun test (lst fuzz / prop)
  (if (cdr lst)
    (and
      (setq prop (/ (caar lst) (caadr lst)))
      (equal prop (/ (cadar lst) (cadadr lst)) fuzz)
      (equal prop (/ (caddar lst) (caddr (cadr lst))) fuzz)
      (test (cdr lst) fuzz)
    T
LE
Re: list question
« Reply #5 on: October 07, 2007, 05:30:52 PM »
Hi
Here's my way
  (if (cdr lst)
    (and
    T
c'est bon, Gile...
I see, you are fan of recursion :)
LE
Re: list question
« Reply #6 on: October 07, 2007, 05:32:28 PM »
         lst1
(setq fuzz 1e-4)
Ugly?.... that's looks good :)
gile
  • Marseille, France
Re: list question
« Reply #7 on: October 08, 2007, 01:46:25 AM »
c'est bon, Gile...
Gracias Luis, esta la elegancia francesa  8-)
Most of the the time it's the first thing coming to my mind, and it often allows a more concise code (even it runs slower with long lists...)
Here's the same translated in iterative form
(defun test2 (lst fuzz / loop prop)
  (setq loop T)
  (while (and loop (cdr lst))
    (if (and
      (setq lst (cdr lst))
      (setq loop nil)
  loop
« Last Edit: October 08, 2007, 06:12:14 AM by gile »
Joe Burke
Re: list question
« Reply #8 on: October 11, 2007, 08:18:25 AM »
I feel like such an idiot. I forgot I posted this topic. Duh...
Anyway, thanks for all the interesting suggestions.
What I did was similar to Luis' solution using divide. Later I ran into the fact the first value in each sublist might be zero which causes a divide by zero error. That's where I left it, without a way around that problem.
gile
  • Marseille, France
Re: list question
« Reply #9 on: October 11, 2007, 10:14:35 AM »
Hi Joe,
Is it a points list (2 or 3 items in each sublist) ?
And want you evaluate if all points are colinear ?
In this case, I had this little routine :
(defun linearp (lst)
  (or
    (null (cddr lst))
    (if (null (inters (car lst) (cadr lst) (car lst) (caddr lst)))
     (linearp (cdr lst))
_$ (linearp '((24.0 305.333 17.3333)
T
« Last Edit: October 11, 2007, 12:22:24 PM by gile »
Joe Burke
Re: list question
« Reply #10 on: October 12, 2007, 08:03:58 AM »
Hi Joe,
Hi gile,
The values in each sub-list roughly represent the bounding box of an annotative mtext object. One sub-list for each annotative scale. They are proportional to each other when the bounding box (handles) have not been changed for one or more scales independent of the others. That's what I'm trying to test for.
I think I found a way to avoid the divide by zero error.
Thanks anyway  :-)
Re: list question
« Reply #11 on: October 12, 2007, 08:44:35 AM »
Perhaps I don't understand, but if you are testing a group of bounding boxes for ratios could
you compare the width to height ratios?
(setq ratio (/ (distance p1 p2) (distance p2 p3)))
ElpanovEvgeniy
  • Moscow (Russia)
Re: list question
« Reply #12 on: October 12, 2007, 08:45:45 AM »
Other a way..
(defun test-1 (lst)
 (setq lst (vl-sort lst '(lambda (a b) (<= (car a) (car b)))))
 (equal (distance (car lst) (last lst)) (apply '+ (mapcar 'distance lst (cdr lst))) 1e-3)
) ;_  defun
Re: list question
« Reply #13 on: October 12, 2007, 08:52:52 AM »
Good to see you Evgeniy, I hope all is well.
ElpanovEvgeniy
  • Moscow (Russia)
Re: list question
« Reply #14 on: October 12, 2007, 09:00:25 AM »
  You still remember me?  :-)
(defun area-polygon (lst)
 (/ (apply (function +)
           (mapcar (function (lambda (a b) (* (+ (car a) (car b)) (- (cadr a) (cadr b)))))
                   (cons (last lst) lst)
                   lst
           ) ;_  mapcar
    ) ;_  apply
    -2.
 ) ;_  -
) ;_  defun
(defun test-2 (lst)
 (and (equal 0. (area-polygon lst) 0.01) (equal 0. (area-polygon (mapcar 'cdr lst)) 0.01))
) ;_  defun
