Author Topic: Save Drawing  (Read 7320 times)
A_LOTA_NOTA
Re: Save Drawing
« Reply #15 on: August 17, 2007, 07:51:17 PM »
Try
(defun c:TEST ()
  (initdia)
  (command ".SAVEAS")
This worked good for "SAVEAS" but now I have the same problem when closing a drawing. If I type close at the command line I get the dialog asking if I want to save changes. But if I use Close in a lisp it prompts me to save at te command line.
Re: Save Drawing
« Reply #16 on: August 17, 2007, 08:46:09 PM »
the mechanism is the same for the save/saveas dialogs
A_LOTA_NOTA
Re: Save Drawing
« Reply #17 on: August 17, 2007, 11:30:24 PM »
So may be I need to run some sort of test to see if the drawing needs to be saved before closing it?
Re: Save Drawing
« Reply #18 on: August 17, 2007, 11:33:32 PM »
Have a look at the DBMOD system variable.
A_LOTA_NOTA
Re: Save Drawing
« Reply #19 on: August 17, 2007, 11:36:08 PM »
Thank you! Looks like that will work!
added: After more thought I shouldn't need to do any testing. If I tell AutoCAD I want to close a drawing it does the testing for me. But I don't get the "Save Changes Yes No Cancel" dialog.
« Last Edit: August 17, 2007, 11:45:11 PM by A_LOTA_NOTA »
Re: Save Drawing
« Reply #20 on: August 17, 2007, 11:45:39 PM »
You should also look at at the DWGTITLED variable
A_LOTA_NOTA
Re: Save Drawing
« Reply #21 on: August 17, 2007, 11:49:52 PM »
I have that one in my code & everything works great. But I had to make my own DCL for the "Do you want to save changes". But I shouldn't have to do that! AutoCAD knows the changes have been made & prompts me to save. But it does it at the command line, not with the DCL like it would if I typed "Close" at the command prompt.
Re: Save Drawing
« Reply #22 on: August 17, 2007, 11:52:17 PM »
added: ... But I don't get the "Save Changes Yes No Cancel" dialog.
Have a look at the initdia Help .. some commands do not make use of it.
reading the help now, I note that .SaveAs is not mentioned, so it's usage IS a bonus. ;-)
A_LOTA_NOTA
Re: Save Drawing
« Reply #23 on: August 17, 2007, 11:58:24 PM »
Kerry,
 I just learned about "Initdia" at the beginning of this thread. When I had the same problem with "SAVEAS" as I'm having with "CLOSE". It fixed the saveas problem but doesn't seam to change close.
I have looked in the help file for '06 & '08. Didn't find it in either one.
A_LOTA_NOTA
Re: Save Drawing
« Reply #24 on: August 18, 2007, 12:02:59 AM »
If I use the following code I just get prompted at the command line to save the drawing.
(defun c:TEST ()
  (initdia)
  (command ".Close" puase)
Re: Save Drawing
« Reply #25 on: August 18, 2007, 12:04:21 AM »
I'm interested (from a design perspective) why you  or your users would not be happy with the default command line Prompt.
A_LOTA_NOTA
Re: Save Drawing
« Reply #26 on: August 18, 2007, 12:09:10 AM »
It would work fine. But if I type "Close" at the command prompt or click "file" then "exit", AutoCAD gives a dialog asking if I would like to save changes. So in trying to make my program act like a standard AutoCAD command.
Just picky I guess.....
Re: Save Drawing
« Reply #27 on: August 18, 2007, 12:11:16 AM »
(defun c:TEST ()
  (initdia)
I haven't tested, I'll leave that to you, but I don't believe you need the 'pause ...
A_LOTA_NOTA
Re: Save Drawing
« Reply #28 on: August 18, 2007, 12:16:19 AM »
(defun c:TEST ()
  (initdia)
No, the pause is not need. I was posting the code more for the fact that I tried INITDIA and it doesn't change anything. And so someone could see a part of what I was trying to do & could may be point out why I don't get the dialog box like I do if entering "close" at the comand prompt.
A_LOTA_NOTA
Re: Save Drawing
« Reply #29 on: August 18, 2007, 09:57:56 AM »
Got it!!
(defun c:TEST1 ()
  (vla-sendcommand
    ".close ")
