Author Topic: Grid control Method SelCurRow Bug?  (Read 4537 times)
« on: June 05, 2007, 01:58:30 PM »
This method will force an entire row to be selected and will also scroll the Grid to ensure the row is visible.
Pass in a -1 if you wish to deselect the current selection.
But the "scroll the Grid to ensure the row is visible" part doesn’t want to work for me
Re: Grid control Method SelCurRow Bug?
« Reply #1 on: June 05, 2007, 05:38:05 PM »
Dan, Can you post this as a bug at Sourceforge ( with a sample ODC and LSP )
« Reply #2 on: June 05, 2007, 10:36:06 PM »
I can do that  :-)
« Reply #3 on: June 05, 2007, 11:31:14 PM »
Daniel,
I added a button and defined an Event Handler ;
Note that I've used the row as (GetRowCount less 1)
(DEFUN c:DwgProp_FormDwp_SelectCurrentRow_OnClicked (/)
  (ALERT (ITOA (ODCL_GRID_GETROWCOUNT DwgProp_FormDwp_GridProp)))
  (ODCL_GRID_SELCURROW
    (- (ODCL_GRID_GETROWCOUNT DwgProp_FormDwp_GridProp) 1)
.. and changing the offending line in c:DwgProp_FormDwp_ButtonAddItem_OnClicked seems to work
      ;;(ODCL_GRID_SELCURROW DwgProp_FormDwp_GridProp (1+ nRow))
                                                       ;<- Bug? <<<<<<<<
      (ODCL_GRID_SELCURROW DwgProp_FormDwp_GridProp nRow)
added:
So the issue is that the row count is Zero based , { I think }
PS added:
BTW, nice code :-)
« Last Edit: June 05, 2007, 11:37:47 PM by Kerry Brown »
« Reply #4 on: June 05, 2007, 11:44:38 PM »
That fixed it. So it wasn’t a bug , but my lack of ODCL knowledge and a lack of good coffee
Thanks a ton Kerry
« Reply #5 on: June 05, 2007, 11:47:49 PM »
No Worries :-) you're welcome.
I'll add a note to the Report that it's resolved and point back here.
