Author Topic: Dynamic Block within a multi-view block  (Read 5674 times)
spawnd
« on: May 15, 2007, 11:02:34 AM »
Is it possible to have a dynamic block in a multi-view block?  I am tring to create a exterior wall light that has different mounting heights and is either switched or a photocell light.
I have created the 3d light, front view and I have the dynamic block.  They are all assembled in the multi-view block but the dynamic block lost all the properties.
Thanks for the help
whdjr
Re: Dynamic Block within a multi-view block
« Reply #1 on: May 15, 2007, 11:35:47 AM »
Dynamic Blocks do not do 3D.  Sorry. :-(
Kate M
« Reply #2 on: May 15, 2007, 11:47:33 AM »
That also sounds like ADT, and I think Dynamic Blocks behave differently in verticals. Not to say you can do what you want, but be aware of the differences.
spawnd
« Reply #3 on: May 15, 2007, 12:13:18 PM »
Sorry, yes I am running ADT 2006.  The top 2d view of the multi-view block is the only part that I want to be dynamic.
whdjr
« Reply #4 on: May 16, 2007, 05:44:45 PM »
You could try to associate your parameters to the top view but my gut tells me it's not going to work.
Mr Cory
« Reply #5 on: May 16, 2007, 11:43:10 PM »
Why not make the dynanic block act as the mvb? What i mean is, if you copy/paste each block in the multi view block into your dynamic block and create a vis state for each one, you should get the same effect as the mvb apart from it wont change automatically
