Author Topic: Copying Viewports  (Read 3527 times)
DaveW
Re: Copying Viewports
« Reply #15 on: April 17, 2007, 12:35:03 PM »
Sounds like a little VB with transform could do both. It would be a nive free utility. Just get the viewport and everything in it at the same time. I have some code that I use for ballooning in PS that I got a bit of help on here at the swamp, that gets the centroids of the solids. it seems easy enough to mod it to just get the objects and their locations. I will try it next week if I get some time.
Luke
« Reply #16 on: April 17, 2007, 01:39:02 PM »
I'm not necessiarly as interested in the MS things as I am in the properties of the viewport.  Scale, layer control, shade plot, etc.  So no way to default it to "ON" huh?
Josh Nieman
« Reply #17 on: April 17, 2007, 02:16:33 PM »
Not that I'm aware.  But you get all the other goodies at least.
DaveW
« Reply #18 on: April 17, 2007, 02:36:17 PM »
You may want give Chuck's code, on this thread: http://www.theswamp.org/index.php?topic=12128.msg151857#msg151857 , a whirl.
It may be tweakable to do what you need.
Dinosaur
« Reply #19 on: April 17, 2007, 02:43:41 PM »
Design Center will do this by copying the entire layout into a different drawing.  Similar, you can copy individual layout tabs within the same drawing and the viewports will retain all properties.
