Author Topic: Copying Viewports  (Read 3530 times)
Luke
Copying Viewports
« on: April 17, 2007, 10:54:28 AM »
Wow I can beleive after 14 years of using AutoCAD I'm just now finally asking this question :?...
Is there a way to copy a viewport or viewports from one layout tab to another inside the same drawing or out to a different drawing and get it to actually copy as a viewport, layers on-off, plot hidden, scale, position, etc, etc?
Luke
Luke
Re: Copying Viewports
« Reply #1 on: April 17, 2007, 10:55:07 AM »
Oh yeah using Standard AutoCAD 2008 full version
« Reply #2 on: April 17, 2007, 10:56:06 AM »
Try it! :-)
You might be surprised. *Hint* ctrl+c
craigr
« Reply #3 on: April 17, 2007, 10:57:19 AM »
I did this quite a few times when we were using LT98, by copying it to the Windows clipboard then into the new dwg.
Since we have switched to LT2005, it no longer works.
craigr
Josh Nieman
« Reply #4 on: April 17, 2007, 11:30:50 AM »
Works without a hitch... but there's a catch... remember to select the vports and make sure "Show viewport objects" is checked.
Luke
« Reply #5 on: April 17, 2007, 11:50:14 AM »
ctrl+c does not do it for me.  The viewport copies but when I past it it just comes in as a  rectangle (or whatever shape is drawn).
Where is the check box for "show viewport objects"?
craigr
« Reply #6 on: April 17, 2007, 11:51:49 AM »
That's exactly what happens to me.
It would be great if it was just a 'settings' issue.
craigr
Josh Nieman
« Reply #7 on: April 17, 2007, 11:51:58 AM »
I select the viewport, and access it via the right click menu... it's also in the properties of the viewport.
Josh Nieman
« Reply #8 on: April 17, 2007, 11:52:15 AM »
craigr
It is.
Tuoni
  • I do stuff, and things!
« Reply #9 on: April 17, 2007, 11:55:20 AM »
Brill... Been wondering how to do that for a while.  Thanks :)
Luke
« Reply #10 on: April 17, 2007, 11:56:43 AM »
OK so I've partially got it.  But when I paste the VP into my new layout or different drawing I have to go into the properties and toggle the "ON" to yes.  It defaults to NO on a paste.  Is there a way to set the default to YES?
« Reply #11 on: April 17, 2007, 11:59:10 AM »
Nope......
Josh Nieman
« Reply #12 on: April 17, 2007, 12:02:46 PM »
If you can find a way, I'd be extremely grateful!!  It took me long enough to figure out the trick I just told you, lol!  But yea... for now, I am just used to ctrl+v, select, rclick, hover on 'display vport objects', and checking "yes"
Birdy
« Reply #13 on: April 17, 2007, 12:08:37 PM »
From one layout to another, in the same file it works.
But to a new drawing....?
No, unless you copy MS object WITH the viewport.
(unless I'm missing something TOTALLY COOL.)
Josh Nieman
« Reply #14 on: April 17, 2007, 12:12:25 PM »
No, to see what's in model space.. you'd have to have that stuff in model space.  I have often ctrl+shift+c copied objects from one drawing's model space using the origin as the reference point, and then pasted those objects into another drawing at 0,0,0 and then copied viewports.  Since viewports look at a  specific area of model space based on the coordinates, it works like a charm.
