Author Topic: Counting Blocks  (Read 20247 times)
Guest
Re: Counting Blocks
« Reply #15 on: April 11, 2007, 11:04:15 AM »
Luke: you can turn off the borders of the table so you don't see the individual cells.
ML
Re: Counting Blocks
« Reply #16 on: April 11, 2007, 11:19:38 AM »
I may be repeating something that has already been mentioned in this post but I tried bcount and it is really cool but I noticed that it only seems to address Block (inserted) references but it does seem to break them down between paper and Model. It does not seem to address Block Definitions.
I have a VBA module I would be glad to share if it would help anyone.
It gives you Block references in Model, Paper and Block Table Definitions in the drawing.
Luke
Re: Counting Blocks
« Reply #17 on: April 11, 2007, 12:08:48 PM »
Mark,
The code:
cnt (1- (itoa (sslength ss)))
Results in the following:
ERROR: bad argument type: numberp: "3"
Any thoughts?
ML
Re: Counting Blocks
« Reply #18 on: April 11, 2007, 12:11:58 PM »
Not sure Luke, sorry  :-(
Luke
Re: Counting Blocks
« Reply #19 on: April 11, 2007, 12:16:59 PM »
Sorry, I was hoping Mark Thomas who gave me the code might be able to help.
Thanks,
Luke
ML
Re: Counting Blocks
« Reply #20 on: April 11, 2007, 12:19:07 PM »
What is the code suppose to do?
Luke
Re: Counting Blocks
« Reply #21 on: April 11, 2007, 12:19:58 PM »
ML, not sure if you read any of the posting above this but it pretty much explains it all in great detail.
Re: Counting Blocks
« Reply #22 on: April 11, 2007, 12:42:47 PM »
Mark,
The code:
Any thoughts?
Try this:
(itoa (1- (sslength ss)))
Luke
Re: Counting Blocks
« Reply #23 on: April 11, 2007, 12:45:52 PM »
Nailed it!  Thanks a ton!
Crank
Re: Counting Blocks
« Reply #24 on: April 11, 2007, 12:53:14 PM »
You can also do this in diesel:
$(-,$(getenv, blk_count),1)
Luke
Re: Counting Blocks
« Reply #25 on: April 11, 2007, 01:07:48 PM »
So just to be clear here Crank, you would continue using the original code but your Diesel Expression would subtract 1?
ML
Re: Counting Blocks
« Reply #26 on: April 11, 2007, 01:10:06 PM »
I'm sorry
I would use VBA to get the same results but it would probably result in more code
ML
Re: Counting Blocks
« Reply #27 on: April 11, 2007, 01:19:40 PM »
If you put this code in a Sub Module and run it, you will get the count for Blocks and Block References
Sub Blocks_Count()
Dim Blks As AcadBlocks
Dim BLCollect As AcadSelectionSet
Dim GCode(0) As Integer
Dim GData(0) As Variant
Dim GPCode As Variant
Dim GPData As Variant
Set Blks = ThisDrawing.Blocks
GCode(0) = 0
GData(0) = "Insert"
GPCode = GCode
GPData = GData
 Set BLCollect = ThisDrawing.SelectionSets.Add("BLOCKREFS")
BLCollect.Select acSelectionSetAll, , , GPCode, GPData
 MsgBox "There are " & Blks.Count & " blocks in this drawing and", vbInformation, "Blocks"
 MsgBox BLCollect.Count & " Block References", vbInformation, "Block References"
 'MsgBox "There are " & ThisDrawing.Blocks.Count & " block(s) in the block table and " & BLCollect.Count & " blocks inserted (Blockref) in the drawing", vbInformation, "Block Information"
BLCollect.Delete
 Set BLCollect = Nothing
Thanks to Keith for the help in writing this
Crank
Re: Counting Blocks
« Reply #28 on: April 11, 2007, 01:46:38 PM »
That's what it does. But lisp is also ok.
With diesel you can minipulate the routine for each situation. Now you want to substract 1, but the next time you perhaps need the exact amount.
Luke
Re: Counting Blocks
« Reply #29 on: April 11, 2007, 01:48:08 PM »
Yes I see, I like that better.  I likt the idea of only having 1 lisp, afterall I have to have a different diesel for each block / field I want to update.
Thank you all for you help!
