Author Topic: Best way to store text info in a drawing with .NET?  (Read 3168 times)
sinc
« on: March 31, 2007, 07:12:46 PM »
What's the best way to include user data in a drawing?  I'm looking for something that works basically like the VLAX-LDATA stuff in Lisp.
I tried using the UserData collection on the Document class, but it doesn't seem to be saved with the drawing.  So I'm guessing it needs to be a database-resident entity.
I looked at the DBDictionary and DictionaryWithDefaultDictionary stuff, but I don't think they do what I want.  Those seem to provide dictionaries of ObjectIds, whereas I want to write some string values to the drawing that I can read again the next time the drawing is opened.
Re: Best way to store text info in a drawing with .NET?
« Reply #1 on: March 31, 2007, 07:44:06 PM »
Lab 4 – Database Fundamentals Part 2: Adding Custom Data
« Reply #2 on: March 31, 2007, 08:02:38 PM »
Since the Data is specific to a DataBase
One option is XRecords :
Create your own Dictionary under the Named Object dictionary [NOD]
then Create XRecords under your Dictionary.
sinc
« Reply #3 on: April 01, 2007, 07:47:37 PM »
Thanks.  That's what I was looking for.
TonyT
« Reply #4 on: April 04, 2007, 02:27:00 PM »
And don't forget that you can't store strings > 255 charcters
in an XRecord, unless you break them up into multiple groups.
