Author Topic: Cancel on getfiled  (Read 2939 times)
MvdP
Cancel on getfiled
« on: November 01, 2006, 08:18:53 AM »
I got a question about canceling an getfiled box.
Here is a piece of code what i got.
(SETQ route1 (getfiled "Select file" "Drawing" "dwg" 1))
but when i hit the cancel button in this dialog box or the escape button is this what the command line says:
Command:  nil; error: bad argument type: stringp nil
Can this piece of code be changed/modified so it that when i hit either the cancel or escape button  i will return to my main dialog box.?
Re: Cancel on getfiled
« Reply #1 on: November 01, 2006, 08:26:59 AM »
The var is being set to nil in my test.
I suspect your routine is not handling that condition.
Need more of your code.
MvdP
« Reply #2 on: November 01, 2006, 08:39:51 AM »
CAB here is more of my code.
Here is piece of my DCL
:button { label =  "Tekening Naam"; mnemonic = "N"; fixed_width = true; key = "path";}
:text{  key =  "route";  width = 75;fixed_width = true;}
Here is more  of my LSP
(action_tile "path" "(paden)")
(set_tile "route" route1)
(set_tile "dwgnaam" dwgnaam)
(defun paden ()
  (if (= pq20 nil)
  (setq pq12 (getvar "dwgname"))
  (setq lengte (strlen pq12))
  (if (> lengte 7)
  (setq pq00 (substr pq12 1 7))
  (WHILE (= pq00 "Drawing")
(setq lengte (strlen route1))
(setq nwlengte (- lengte 10))
(setq pq00 (substr route1 nwlengte))
(set_tile "dwgnaam" route1)
(setq naam route1)
(SETQ pq12 nil)
I hope this wil do.
« Last Edit: November 01, 2006, 08:43:47 AM by MvdP »
« Reply #3 on: November 01, 2006, 09:15:42 AM »
Maybe this will work for you.
(defun paden ()
  (if (= pq20 nil)
      (if (> lengte 7)
          (while (= pq00 "Drawing")
            (setq route1 (getfiled "Select file" "Drawing" "dwg" 1))
            (if route1
                (setq naam route1)
                (setq pq12 nil)
              (setq pq00 nil) ; exit paden
MvdP
« Reply #4 on: November 01, 2006, 09:23:58 AM »
Yes CAB it is working.You're a lifesaver.
Thank you so much.
« Reply #5 on: November 01, 2006, 09:37:03 AM »
You're welcome, any time.
