Author Topic: Translations ...  (Read 8865 times)
Translations ...
« on: September 16, 2006, 07:59:40 PM »
I thought we could use this thread for notes about translations between VB and C#  [ or vice versa ]
added Note :
I'm currently using VS2005 for coding and SharpDevelop 2.0 for translations.
« Last Edit: September 16, 2006, 08:09:47 PM by Kerry Brown »
Re: Translations ...
« Reply #1 on: September 16, 2006, 08:07:41 PM »
The VBNet code :
If (Not trans Is Nothing) Then
    trans.Dispose()
End If
SharpDevelop 2.0 translates to :
if ((!trans == null))
     trans.Dispose();
This should be :
if (trans != null)
     trans.Dispose();
Added :-
The following does not work because
'Autodesk.AutoCAD.DatabaseServices.Transaction' does not contain a definition for 'isNull'
if (!trans.isNull())
     trans.Dispose();
Edit : piccy added :-
« Last Edit: September 16, 2006, 10:00:47 PM by Kerry Brown »
« Reply #2 on: September 16, 2006, 08:17:00 PM »
The VBNet code :
Dim objId As ObjectId
For Each objId In btr
    Dim dynblkUtil As New DynamicBlock.DynBlockUtil(objId)
    dynblkUtil.ListDynBlock()
Next
ObjectId objId ;
foreach ( objId in btr)
    DynamicBlock.DynBlockUtil dynblkUtil = new DynamicBlock.DynBlockUtil(objId);
    dynblkUtil.ListDynBlock();
This should be :
foreach ( ObjectId objId in btr)
edit : piccy added :-
« Last Edit: September 16, 2006, 10:18:04 PM by Kerry Brown »
« Reply #3 on: September 16, 2006, 08:30:51 PM »
The VBNet code :
            Dim db As Database = HostApplicationServices.WorkingDatabase
            Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
            Dim trans As Autodesk.AutoCAD.DatabaseServices.Transaction = tm.StartTransaction
    Autodesk.AutoCAD.DatabaseServices.TransactionManager tm = db.TransactionManager;
    Autodesk.AutoCAD.DatabaseServices.Transaction trans = tm.StartTransaction;
The last line should be :
Autodesk.AutoCAD.DatabaseServices.Transaction trans = tm.StartTransaction();
and if these using statement aliases  are added to the code :
using AcApp = Autodesk.AutoCAD.ApplicationServices.Application;
using AcDb = Autodesk.AutoCAD.DatabaseServices;
the code block could be revised to :
AcDb.TransactionManager tm = db.TransactionManager;
AcDb.Transaction trans = tm.StartTransaction();
« Last Edit: September 16, 2006, 09:56:51 PM by Kerry Brown »
« Reply #4 on: September 16, 2006, 08:39:36 PM »
The VBNet code :
                Dim bt As BlockTable
                Dim btr As BlockTableRecord
                bt = tm.GetObject(db.BlockTableId, OpenMode.ForRead)
                btr = tm.GetObject(bt.Item(BlockTableRecord.ModelSpace), OpenMode.ForRead)
BlockTable bt;
 BlockTableRecord btr;
 bt = tm.GetObject(db.BlockTableId, OpenMode.ForRead);
 btr = tm.GetObject(bt.Item(BlockTableRecord.ModelSpace), OpenMode.ForRead);
This should be :
 BlockTable bt = (BlockTable)trans.GetObject(db.BlockTableId, OpenMode.ForRead);
 BlockTableRecord btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
« Last Edit: September 16, 2006, 10:22:14 PM by Kerry Brown »
« Reply #5 on: September 16, 2006, 09:11:36 PM »
The VBNet code :
               If blkRefId.IsNull Then
                    ' Nothing selected
                    Exit Try
                End If
if (blkRefId.IsNull)
// Nothing selected
break; // TODO: might not be correct. Was : Exit Try
This should be < To be confirmed > :
// Nothing selected
return; // TODO: To be confirmed
« Reply #6 on: September 16, 2006, 09:23:17 PM »
The VBNet code :
                Dim blkRef As BlockReference
                blkRef = tm.GetObject(blkRefId, OpenMode.ForWrite)
BlockReference blkRef;
blkRef = tm.GetObject(blkRefId, OpenMode.ForWrite);
This should be :
    BlockReference blkref = (BlockReference)tm.GetObject(blkRefId, OpenMode.ForWrite);
« Reply #7 on: September 16, 2006, 09:35:36 PM »
The VBNet code :
            Catch
                ed.WriteMessage("Oops!" & vbCrLf)
            End Try
    catch {
ed.WriteMessage("Oops!" + Constants.vbCrLf);
We'll see a lot of this one ...
This should be  :
    catch {
ed.WriteMessage("Oops!" + "\n");
« Reply #8 on: September 16, 2006, 09:47:10 PM »
.. and this is where the definition came from :
« Reply #9 on: September 16, 2006, 10:12:59 PM »
The VBNet code :
        Public Property Value() As String
            Get
                If m_prop.Value Is Nothing Then
                    Return ""
                Else
                    Return m_prop.Value.ToString
                End If
            End Get
public string Value {
get {
if (m_prop.Value == null)
return "";
else
return m_prop.Value.ToString;
This should be  :
get {
return "";
else
return m_prop.Value.ToString() ;
« Reply #10 on: September 16, 2006, 10:32:23 PM »
I need help with this one .. any ideas .. ? ?
The VBNet code :
        <System.Diagnostics.DebuggerStepThrough()> Private Sub InitializeComponent()
            Me.m_bnOk = New System.Windows.Forms.Button()
            Me.m_Label = New System.Windows.Forms.Label()
            Me.m_DataGrid = New System.Windows.Forms.DataGrid()
            CType(Me.m_DataGrid, System.ComponentModel.ISupportInitialize).BeginInit()
            Me.SuspendLayout()
private void InitializeComponent()
this.m_bnOk = new System.Windows.Forms.Button();
this.m_Label = new System.Windows.Forms.Label();
this.m_DataGrid = new System.Windows.Forms.DataGrid();
(System.ComponentModel.ISupportInitialize)this.m_DataGrid.BeginInit();
this.SuspendLayout();
« Reply #11 on: September 16, 2006, 10:58:00 PM »
Need Help with this one too ...
VBNet ..
            Get
                    Return ""
                Else
                End If
            End Get
            Set(ByVal Value As String)
                If m_prop.ReadOnly = True Then
                    MessageBox.Show("Property is read-only")
                Else
                    Try
                        Select Case m_prop.PropertyTypeCode
                            Case Is = PropTypeCode.RTNONE
                            Case Is = PropTypeCode.RTSHORT
                                m_prop.Value = System.Convert.ToInt16(Value)
                            Case Is = PropTypeCode.RTLONG
                                m_prop.Value = System.Convert.ToInt64(Value)
                            Case Is = PropTypeCode.RTREAL
                                m_prop.Value = System.Convert.ToDouble(Value)
                            Case Is = PropTypeCode.RTENAME
                            Case Is = PropTypeCode.RTPOINT
                            Case Is = PropTypeCode.RT3DPOINT
                            Case Is = PropTypeCode.RTSTR
                                m_prop.Value = Value
                        End Select
                    Catch e As System.Exception
                        MessageBox.Show(e.Message)
                    End Try
                End If
            End Set
        End Property
C# ..
all the red lines display this error
Cannot implicitly convert type 'DynamicBlock.PropTypeCode' to 'short'. An explicit conversion exists (are you missing a cast?)
I could cast to short (Int16) ie
(int16)PropTypeCode.RTSHORT:
but it doesn't feel right for all of them .. 'cause I'm a little brain dead.
        public string Value
            get
                    return "";
                else
                    return m_prop.Value.ToString();
            set
                if (m_prop.ReadOnly == true)
                    MessageBox.Show("Property is read-only");
                else
                    try
                        switch (m_prop.PropertyTypeCode)
                            case PropTypeCode.RTNONE:
                                break;
                            case PropTypeCode.RTSHORT:
                                m_prop.Value = System.Convert.ToInt16(value);
                                break;
                            case PropTypeCode.RTLONG:
                                m_prop.Value = System.Convert.ToInt64(value);
                                break;
                            case PropTypeCode.RTREAL:
                                m_prop.Value = System.Convert.ToDouble(value);
                                break;
                            case PropTypeCode.RTENAME:
                                break;
                            case PropTypeCode.RTPOINT:
                                break;
                            case PropTypeCode.RT3DPOINT:
                                break;
                            case PropTypeCode.RTSTR:
                                m_prop.Value = value;
                                break;
                    catch (System.Exception e)
                        MessageBox.Show(e.Message);
These are the enumerators ..
public enum PropTypeCode
        RTREAL = 40,
        //kDouble or AcDb::kDxfReal ''5001
        RTSHORT = 70,
        // kShort or AcDb::kDxfInt16 ''5003
        RTSTR = 1,
        //kString or AcDb::kDxfText ''5005
        //The following are not used in Rio
        RTNONE = -9999,
        //kNone or AcDb::kDxfInvalid ''5000
        RTPOINT = 10,
        //kPoint2d or AcDb::kDxfXCoord ''5002
        RTENAME = 91,
        //kOldId or AcDb::kDxfInt32+1 ''5006
        RT3DPOINT = 11,
        //kPoint3d or AcDb::kDxfXCoord+1 ''5009
        RTLONG = 90
        //kLong or AcDb::kDxfInt32 ''5010
« Last Edit: September 16, 2006, 11:01:48 PM by Kerry Brown »
« Reply #12 on: September 16, 2006, 11:37:18 PM »
Just in case anyone doesn't know what I'm trying to convert ...
TonyT
« Reply #13 on: September 17, 2006, 02:40:28 AM »
I haven't played with SharpDevelop, but from what
you posted, I'd say that its code translation needs
some work :-)
this:
should be:
  ((System.ComponentModel.ISupportInitialize)this.m_DataGrid).BeginInit();
« Reply #14 on: September 17, 2006, 06:54:58 PM »
I don't have time to participate these days but just want to give a nod your way Kerry -- this thread (translations, equivalencies etc) is a good idea.
