Author Topic: Custom hatch issues  (Read 2793 times)
Barry Clark
Custom hatch issues
« on: August 10, 2006, 12:05:42 PM »
OK, I made a test hatch pattern just so I can get my feet wet with the process. I borrowed the definition from a tutorial site. Worked yesterday, doesn't work today. I tried everything.
I even went and borrowed from the ACAD.PAT file this:
*ANGLETEST, Angle test
0, 0,0, 0,.275, .2,-.075
90, 0,0, 0,.275, .2,-.075
then saved it as Angle Test.pat
and I still get an error that says there is a problem in the pattern file.
Any ideas? Something I overlooked?
Sdoman
Re: Custom hatch issues
« Reply #1 on: August 10, 2006, 12:57:02 PM »
Here are a couple errors I've seen:
Check that there is a blank line at the end of the file.
Only one pattern allowed per file.
Barry Clark
« Reply #2 on: August 10, 2006, 01:06:17 PM »
Thanks for the reply.
I checked my file and there is only one pattern and no empty blanks.
I modified the file to read as follows:
*testthing, test thing
45,0,0,0,.25
It got me a little further. I can now see the swatch in the window of the Hatch Edit box; however, when I try to apply, on the command line, I get this:
"Bad pattern definition file:
Missing parameter on line 2."
« Reply #3 on: August 10, 2006, 01:26:27 PM »
Hi Barry,
Both of the files work for me. Make sure the file name is identical to the pattern name and that you have a CarriageReturn after the last character.
Barry Clark
« Reply #4 on: August 10, 2006, 01:28:46 PM »
Hi Barry,
Hey Jeff. Thanks for the reply. CarriageReturn? I am familiar with this in VB, but what is that in this case? Is it \r? How do I apply it?
would it be
45, 0,0, 0,.25\r
« Last Edit: August 10, 2006, 01:39:41 PM by Barry Clark »
« Reply #5 on: August 10, 2006, 01:43:21 PM »
Hit ENTER.......
45, 0,0, 0,.25
Note the blank line after the ....,.25
Barry Clark
« Reply #6 on: August 10, 2006, 01:43:53 PM »
Oh, for the love of Pete. I am just trying to be stupid, aren't I?
*hits ENTER*
Barry Clark
« Reply #7 on: August 10, 2006, 01:56:12 PM »
Can shapefiles be inserted?
I tried something like this and the shapes were not inserted.
45, 0, 0, 0, .25, .5,-.05,[X,X.shx,S=1,R=0.0,X=0.0,Y=0.0],-.05
Any thoughts?
SPDCad
« Reply #8 on: August 10, 2006, 03:38:56 PM »
Is the hatch pattern file name the same as hatch pattern name?
ie.
file name = ANGLETEST.pat
Pattern code:
You get an error message when they differ. Usually this is a common error I make with my custom hatch patterns.
Hope it helps.
AutoCAD 2010, w/ OpenDCL
visit: http://reachme.at/spd_designs
Sdoman
« Reply #9 on: August 10, 2006, 05:36:50 PM »
Jeff said it better: "Carriage Return".  That's what I meant by blank line at EOF, sorry for the confusion...  *typing on old typewriter* tat, tat, tat, tat, ta, tat, DING, Return!
