Author Topic: string manipulation  (Read 5653 times)
Re: string manipulation
« Reply #15 on: July 01, 2006, 08:22:35 PM »
It is better to find approximate solution to an exact problem than to find an exact solution to approximate problem.
Author Unknown
matrix2005in
« Reply #16 on: July 02, 2006, 12:22:22 AM »
hi
this is what i want excellent code...thanks verymuch
« Reply #17 on: July 02, 2006, 01:26:00 AM »
I want excellent code, too, but alas, all I have is me to write it .....  :evil:
mathew, a well placed period "." or comma "," would change the meaning of that sentence quite a bit.... :-)
Kerry, I knew we were right and Jon was missing the mark.  :kewl:
CAB, well quoted!
Andrea
« Reply #18 on: July 02, 2006, 08:01:23 PM »
this is mine...
(setq t1 "ABCDEFGHIJK")
(setq list2 nil)
(while (/= t1 "")
  (setq list1 (substr t1 1 3))
  (setq list2 (append list2 (list list1)))
  (setq t1 (substr t1 4))
(foreach n list2
  (if (not text1)(setq text1 " "))
  (setq text1 (strcat text1 " " n))
(setq text2 (substr text1 3))
text2 = "ABC DEF GHI JK"
list2 = ("ABC" "DEF" "GHI" "JK")
« Last Edit: July 02, 2006, 08:11:06 PM by Andrea »
Keep smile...
« Reply #19 on: July 03, 2006, 06:17:12 AM »
hi
...thanks verymuch
Have a play with this too .. though not as easy to understand, perhaps ..
(DEFUN numsOnly (str /)
    (VL-LIST->STRING (VL-REMOVE-IF-NOT '(LAMBDA (n) (AND (> n 47) (< n 58)))
                                       (VL-STRING->LIST str)
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #20 on: July 03, 2006, 07:46:51 AM »
(defun test (str)
  ; Not used VL-...
  (if (= str "")
    (if (< 47 (ascii str) 58)
      (strcat
(substr str 1 1)
(test (substr str 2))
      ) ;_  strcat
    ) ;_  if
  ) ;_  if
) ;_  defun
