Author Topic: Copying objects to new db  (Read 8038 times)
« on: June 25, 2006, 08:43:24 PM »
I'm struggling with copying objects from one db into a new one, I have done very little with Documents and new db's , blocks etc so any help would be great.
It works but if I open the new drawing with objects that contained xdata in the original there are errors.
Will this mean I need to 'deep' clone? I'll give it a go anyhow and see how it goes.
Here's what I have so far -
using System;
using System.IO;
using System.Windows.Forms;
using System.Collections;
using System.Data;
using System.Data.OleDb;
using Autodesk.AutoCAD.GraphicsInterface;
using Autodesk.AutoCAD.Windows.ToolPalette;
namespace copytester
/// <summary>
/// Summary description for Class1.
/// </summary>
public class Class1
[CommandMethod("TESTCOPY")]
public static void CopyToNewDb()
Editor ed =
Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
//Get an entiy to copy to new drg:
PromptEntityResult res = ed.GetEntity("\nSelect an entity to copy to new drg:");
if(res.Status == PromptStatus.Cancel || res.Status != PromptStatus.OK)
return;
Transaction tr = db.TransactionManager.StartTransaction();
try
//Get the ent to copy:
Entity ent = tr.GetObject(res.ObjectId,OpenMode.ForWrite) as Entity;
if(ent == null)
return;
//new db from template, new trans:
Database newdb = new Database(false,true);
newdb.ReadDwgFile(@"C:\DCS_3D\dcs_std.dwt", System.IO.FileShare.None, false,null);
Transaction tr2 = newdb.TransactionManager.StartTransaction();
try
BlockTable bt = tr2.GetObject(newdb.BlockTableId, OpenMode.ForRead, false) as BlockTable;
BlockTableRecord btr = tr2.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
if(btr == null)
return;
//copy our entity to make a new ent to add to new db:
Entity newent = ent.Clone() as Entity;
//append entity to new db:
if(newent == null)
return;
btr.AppendEntity(newent);
tr2.AddNewlyCreatedDBObject(newent,true);
//use existing ent handle for now for drg names:
string filename = @"C:\DCS_3D\testdrgs\drg" + ent.Handle.Value.ToString() + ".dwg";
newdb.SaveAs(filename,null);
tr2.Commit();
tr2.Dispose();
newdb.Dispose();
tr.Commit();
tr.Dispose();
- John Carmack
- J.R.R. Tolkien
Glenn R
Re: Copying objects to new db
« Reply #1 on: June 25, 2006, 09:29:48 PM »
Something like this perhaps:
[CommandMethod("Dolly")]
static public void DollyCommand() {
Editor pEd = acadApp.DocumentManager.MdiActiveDocument.Editor;
PromptEntityResult pRes = pEd.GetEntity("\nSelect an entity to dollify: ");
if (pRes.Status != PromptStatus.OK)
return;
ObjectIdCollection pEntsToClone = new ObjectIdCollection();
pEntsToClone.Add(pRes.ObjectId);
Database pNewDb = new Database(true, true);
using (Transaction pTr = pNewDb.TransactionManager.StartTransaction()) {
BlockTable pBlkTbl = pTr.GetObject(pNewDb.BlockTableId, OpenMode.ForRead, false) as BlockTable;
pNewDb.WblockCloneObjects(pEntsToClone, pBlkTbl[BlockTableRecord.ModelSpace], DuplicateRecordCloning.Ignore, false);
pNewDb.SaveAs(@"C:\Temp\Dolly.dwg", DwgVersion.Current);
Cheers,
Glenn.
« Reply #2 on: June 25, 2006, 09:32:52 PM »
I bet there is a story to go with that name ...
« Reply #3 on: June 25, 2006, 09:51:01 PM »
Cheers,
Glenn.
heh, thanks Gleen, I took that route actually after battling with deepclone and getting nowwhere :)
My result which is very similar only I'm using a template that has our default layers etc. -
Editor ed =
return;
try
//Get the ent to copy, only need id to add to ObjectId collection:
ObjectIdCollection coll = new ObjectIdCollection();
//add our object to copy:
coll.Add(res.ObjectId);
//new db from template:
//wblock entity to new db:
db.Wblock(newdb,coll,new Point3d(),DuplicateRecordCloning.Ignore);
string filename = @"C:\DCS_3D\testdrgs\drg" + res.ObjectId.Handle.Value.ToString() + ".dwg";
newdb.Dispose();
tr.Commit();
tr.Dispose();
I actually want to copy groups into new drgs, I need to get hold of the new objects in the new db now and create a group that matches the one in the model. If I'm adding multiple groups this may be difficult to get the last added ents, more study required :)
- John Carmack
- J.R.R. Tolkien
« Reply #4 on: June 25, 2006, 10:42:19 PM »
Thanks Bobby for the eventhandler samples :)
I should be able to work with this -
using System;
using System.IO;
using System.Data;
/// <summary>
/// </summary>
public class Class1
Editor ed =
return;
try
//add an event handler to catch the newly added db objects:
newdb.ObjectAppended += new ObjectEventHandler(OnObjectAppended);
//delete the event handler:
newdb.ObjectAppended -= new ObjectEventHandler(OnObjectAppended);
newdb.Dispose();
tr.Commit();
tr.Dispose();
private static void OnObjectAppended(object sender, ObjectEventArgs e)
Editor ed =
ed.WriteMessage("\nHandle of new object added to new db: " + e.DBObject.GetType().Name);
Thanks Guys.
« Last Edit: June 25, 2006, 11:17:30 PM by MickD »
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #5 on: June 25, 2006, 11:56:15 PM »
I would be EXTREMELY carefull with the OnObjectAppended event, for several reasons, not the least of which, is that the entity your passed is probably still in an "open for write" state by AutoCAD from memory...
« Reply #6 on: June 26, 2006, 12:03:27 AM »
Is there another way you could suggest?
I did notice the output wasn't quite as I suspected too but this may be normal. If I do a 'move' 'all' in the new drg it only picks up the 1 object as picked from the original drg but the function shows it added twice??.
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #7 on: June 26, 2006, 12:08:41 AM »
I notice your using wblock and not wblockcloneobjects as I used...have you tried it my way?
Glenn R
« Reply #8 on: June 26, 2006, 12:12:17 AM »
Also, try printing up the handle of the object being appended, not the type as your screen cappy goes - this should tell you immediately if the objects are indeed the same...even better, print the objectId's if you can get them, as handles are only guaranteed to be unique for a drawing NOT across all drawings open in a session, whereas objectid's are unique across all drawings open in a given session.
« Reply #9 on: June 26, 2006, 12:57:13 AM »
Ok, the output using just wblock is the first, using wblockcloneobjects is the second -
- John Carmack
- J.R.R. Tolkien
« Reply #10 on: June 26, 2006, 06:15:46 PM »
Of course, now I'm saving the ObjId's of the newly appended objects I'm getting 2 of each and crashes my group creation code.
Some more testing is involved now to see why 'object appended' is being called twice??
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #11 on: June 26, 2006, 07:34:22 PM »
Mick,
Have you used the IdMapping object returned from the wblockcloneobjects? It will contain id's of the original and the clones...you should be able to go from there.
« Reply #12 on: June 26, 2006, 08:35:20 PM »
Is that only in 2007??
I could iterate the db it contains but I already have both db's.
- John Carmack
- J.R.R. Tolkien
Glenn R
« Reply #13 on: June 26, 2006, 08:49:45 PM »
From the ObjectARX 2006 docs:
WblockCloneObjects
Autodesk.AutoCAD.DatabaseServices.IdMapping
WblockCloneObjects(
Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection identifiers,
Autodesk.AutoCAD.DatabaseServices.ObjectId id,
Autodesk.AutoCAD.DatabaseServices.DuplicateRecordCloning cloning,
System.Boolean deferTranslation)
Parameters
identifiers Input Autodesk.AutoCAD.DatabaseServices.ObjectIdCollection object.
id Input Autodesk.AutoCAD.DatabaseServices.ObjectId object.
cloning Input Autodesk.AutoCAD.DatabaseServices.DuplicateRecordCloning object.
deferTranslation Input System.Boolean object.
Return Type
Wraps the following functions:
AcDbDatabase::wblockCloneObjects
« Reply #14 on: June 26, 2006, 09:26:48 PM »
Yes, I knew it returned an IdMapping, I was looking for something obvious like an id collection property...looked harder and found the enumerater...doh!
Anyway, thanks Glenn, works a treat and deleted the reactor -
IdMapping idmap = new IdMapping();
using(Transaction tr2 = newdb.TransactionManager.StartTransaction())
newdb.BlockTableId,OpenMode.ForWrite) as BlockTable;
if(bt == null)
return;
idmap = db.WblockCloneObjects(
coll,bt[BlockTableRecord.ModelSpace],
DuplicateRecordCloning.Ignore,false);
foreach(IdPair idp in idmap)
if(idp.IsPrimary)//otherwise you'll get all which are not req'd in this case!
ed.WriteMessage("\nOriginal db ObjId: {0}, Destination db ObjId: {1}",
idp.Key.ToString(),idp.Value.ToString());
- John Carmack
- J.R.R. Tolkien
