Author Topic: Inside/Outside radius  (Read 7586 times)
John Hancock
« on: May 24, 2006, 03:09:45 PM »
At one time I had a formula that would give me the inside radius of a pipe drawn in 2D if I entered the outside radius.  In other words, the inside radius looked as good as the outside radius. I use R2000 but this computation was from a board draftsman.
cad-waulader
Re: Inside/Outside radius
« Reply #1 on: May 25, 2006, 06:26:21 PM »
Not clear what you're trying to do.
Bob Wahr
« Reply #2 on: May 25, 2006, 07:16:11 PM »
What kind of pipe?
drizzt
« Reply #3 on: May 26, 2006, 09:46:21 AM »
You would have to enter wall thickness somehow right?
Bob Wahr
« Reply #4 on: May 26, 2006, 11:27:05 AM »
I'm guessing that what the formula does is approximates a wall thickness based on O.D.
Swift
« Reply #5 on: May 26, 2006, 12:28:15 PM »
Where I come from we would approximate the OD from the ID.
Just remember though, if the inner diameter is larger than the outer diameter, the hole will be on the outside.
Maverick®
« Reply #6 on: May 26, 2006, 02:20:09 PM »
Good one.  :-D
Greg B
  • Tell me a Joke!
« Reply #7 on: May 26, 2006, 02:29:54 PM »
Heh...
I must be missing something.  Whether you know the I.D. or the O.D. it doesn't matter cause what you really need to know is the thickness of the wall of the pipe.
Say you have a pipe that is 2" in diameter.  The thickness of the wall is 1/8".  That would make the interior diameter 1 3/4".
Too simple, so I must be missing some key information.
Maybe you're looking for some code that figures this out.
John Hancock
« Reply #8 on: May 30, 2006, 11:14:15 AM »
It really doesn't matter what the wall thickness is.  This is simply making the inside radius look as good as the outside radius when drawn as a 2D drawing. It doesn't have to be a pipe it could be two parallel lines filleted at the corner.
John
Maverick®
« Reply #9 on: May 30, 2006, 12:33:15 PM »
  You just add/subtract the distance between the parallel lines to/from the radius you have.
  If you have 2 lines joined with a radius of 36" and you have 2 lines parallel to those 24" away your radius would be 60" or 12" depending on which way you are going.
  Clear as mud?
M-dub
« Reply #10 on: May 30, 2006, 12:46:34 PM »
Clear as mud?
Yep :-D
Now, I'm no piper, so there's a very good chance that I'm way off in left field with this one, but are we talking about the difference between copying one radius versus offsetting it?
Maverick®
« Reply #11 on: May 30, 2006, 12:53:05 PM »
  Clearer Mud.  Yup, that's what he's thinking of M-Dub.  I think so anyway.  BTW I'm not a programmer so if you are looking for a routine to do this for you ...... you'll have to ask someone smarter than I.   :-D
John Hancock
« Reply #12 on: May 30, 2006, 01:27:26 PM »
Maverick,
I think you hit the nail on the head.
John
Bob Wahr
« Reply #13 on: May 30, 2006, 02:06:52 PM »
So you want a program that emulates the OFFSET command exactly?  The formula for calculating the inside radius would be
R2=R1-D Where R1 is the outside radius, R2 is the inside radius and D is the diameter of the pipe.
John Hancock
« Reply #14 on: May 30, 2006, 02:27:50 PM »
I wasn't looking for a program for the inside/outside fillets (radius) but if one is available...
