Author Topic: how to save a zoom to restore after macro is run  (Read 2108 times)
ELOQUINTET
« on: May 17, 2006, 01:28:37 PM »
when i came to work here is discovered we have several macros we use to update attribute values for file name and revision etc. the problem i discovered right away was the attribute only got updated so i decided to add a zoom extents to the beginning. end of story right, wrong. now my boss wants it to go back to the previous "zoom" upon completion. how would i capture the zoom window and restore it at the end. here is my macro:
_.TEXTEVAL 1 _-ATTEDIT _Y *;DWG-FILE *;_C (GETVAR "EXTMIN") (GETVAR "EXTMAX"); _V _R (DWGPATH) ;_N
M-dub
Re: how to save a zoom to restore after macro is run
« Reply #1 on: May 17, 2006, 01:32:47 PM »
This might be a dumb question, but have your tried Zoom;P;?
ELOQUINTET
« Reply #2 on: May 17, 2006, 01:45:42 PM »
urrr please delete you were correct mdub. i am in the middle of so many things i didn't even try the obvious  :oops:
