Author Topic: Autocad shut down...  (Read 1862 times)
Russ
« on: June 23, 2005, 10:01:29 AM »
When I close a .dwg autocad shuts completely down. Any ideas?
David Hall
  • Automatic Duh Generator
« Reply #1 on: June 23, 2005, 10:02:55 AM »
what command are you using to close dwg?  also what is the value of your sdi variable?
Russ
« Reply #2 on: June 23, 2005, 10:26:00 AM »
I close several different ways, but mostly file pull down - close. SDI is set to 0. Whats odd is that if I try to change the SDI to 1 it comes back Invalid. Also, in options the Single-Drawing selection is grayed out and I'm unable to check the check box.
daron
« Reply #3 on: June 23, 2005, 11:02:19 AM »
Repair or reinstall?? Can't see another solution.
craigr
« Reply #4 on: June 23, 2005, 12:00:33 PM »
What Version of AutoCad are you using.
The reason I ask is that We are using 2005LT, and I frequently have 'Errors' when I shut down AutoCad. It doesn't affect the closing dwg, and AutoCad opens again without problems, but it is annoying to get the AutoCad Error message. I have re-installed several times, still there.
It's annoying, but not worth spending many hours trying to fix.
I just figure that they changed something in their shutdown process, since I haven't had the problem with previous releases.
craigr
Russ
« Reply #5 on: June 23, 2005, 12:44:07 PM »
I'm using ADT 3.3
« Reply #6 on: June 23, 2005, 12:59:27 PM »
I don't know about ADT but you can't use SDI 1 in LDT. Could be the for same reasons!
daron
« Reply #7 on: June 23, 2005, 03:09:36 PM »
I used ADT3.3. I say the first thing you should do is in add/remove programs: repair. You'll need your installation cd's, but that would be definately the first thing I'd do.
Russ
« Reply #8 on: June 23, 2005, 03:31:30 PM »
I'll try darons suggestion. Thanks for the input folks.
