Author Topic: Excel to Acad  (Read 1588 times)
nyah
Excel to Acad
« on: May 03, 2012, 11:51:48 AM »
Hi Everyone
Here in the UK we are all soooo excited about the Olympics.....groans :realmad:
That said
Using Datalink you can set up a table that will update itself on the drawing with changes to the excel program however, is there a way that while in excel you have the tag numbers say HV1234 and you change it to HV1235 it updates the cad text on the drawing rather than a table?
Or should I get into the tardice and move foward 100 years?
irneb
Re: Excel to Acad
« Reply #1 on: May 04, 2012, 04:59:29 AM »
Nope, there's some way to change the Excel sheet by typing into the table ... but that doesn't give you a change of the attributes.
You could try using the old Express tool's AttOut & AttIn commands. Only it produces TXT files (tab delimited) and you need to keep the handle column otherwise the link is broken.
