Author Topic: Challenge? Select Like Objects  (Read 2315 times)
M-dub
« on: February 26, 2008, 11:51:00 AM »
This isn't a request for code, disguised as a challenge.  I just thought of it while Cadding away here.
Would it be possible to allow a user to select a number of objects, have your code analyze what they are and how they're arranged in relation to eachother and then go out and find similar instances of the same objects?
I just thought of it while deleting some old rev triangles off a drawing.  These ones were made just using lines and text, rather than the attributed block that we use now.  Like I said, I was just wondering if it would be possible.
Re: Challenge? Select Like Objects
« Reply #1 on: February 26, 2008, 12:05:27 PM »
Having the routine find 3 lines sharing end points is easy enough, but beyond that there would need to be rules for each type of object for a match criterion.
M-dub
« Reply #2 on: February 26, 2008, 12:11:34 PM »
Yeah, I guess you're right... Ah well, thought it might be interesting.
whdjr
« Reply #3 on: February 26, 2008, 02:39:42 PM »
Isn't that kind of like the old SSX command in the ...[Looks around for Michael]... Express Tools
« Reply #4 on: February 26, 2008, 02:41:14 PM »
Krushert
  • FREE BEER Tomorrow!!
« Reply #5 on: February 27, 2008, 12:32:13 PM »
 :-D :-D
KewlToyZ
« Reply #6 on: March 01, 2008, 12:23:16 AM »
The option already exists as a right click in MEP.
Select Similiar.
Why it doesnt exist in regular CAD is likely because of the AEC libraries.
After that your left with qselect.
uncoolperson
« Reply #7 on: March 01, 2008, 01:29:50 AM »
if you ever figure it out, please let me know.... still trying to think it out myself
http://www.theswamp.org/index.php?topic=17492.0
« Reply #8 on: March 01, 2008, 08:35:02 AM »
I've looked at this topic a couple times and sadly must conclude that, as currently defined, I could not help out, even though I would very much like too.
