Author Topic: (C3D '10) angle information  (Read 2220 times)
« on: April 08, 2010, 08:35:12 AM »
I believe this is the same old bug but I thought I'd mention it again.
Using Civil 3D 2010.
Command:[b] _AeccCgAng[/b]
Select first line or [Points]:
Second line:
The acute [b]angle is 89.4622[/b] (dms)
The obtuse angle is 270.1338 (dms)
Command:
Command:
Command: [b]_dimangular[/b]
Select arc, circle, line, or <specify vertex>:
Select second line:
Specify dimension arc line location or [Mtext/Text/Angle/Quadrant]:
[b]Dimension text = 90d13'38"[/b]
Line information.
Command: _AeccCgList
Select object or [Points]:
                          LINE DATA
Begin . . . . .  X: 498679.34'          Y: 1345808.21'
End . . . . . .  X: 498685.82'          Y: 1346245.86'
              Distance: 437.69'           Course: N0° 50' 55"E
                          LINE DATA
Begin . . . . .  X: 498660.83'          Y: 1346246.13'
End . . . . . .  X: 499996.51'          Y: 1346231.64'
              Distance: 1335.77'          Course: S89° 22' 43"E
alanjt
  • Standby for witty remark...
Re: (C3D '10) angle information
« Reply #1 on: April 08, 2010, 09:00:08 AM »
C3D '09
Command: ca
CGANG
Second line:
The acute angle is 60°52'32"
The obtuse angle is 299°07'28"
Command: dan
DIMANGULAR
Select second line:
Dimension text = 60d53'
Dropbox
sinc
« Reply #2 on: April 08, 2010, 09:56:47 AM »
Are you talking about the "acute"/"obtuse" misnomers?  Or something else?
sinc
« Reply #3 on: April 08, 2010, 10:03:18 AM »
Just for comparison, here is the output of a similar command in the Sincpac-C3D:
Command: PtAng
Pick first point or enter Point Number [Multiple]:
Pick vertex or enter Point Number [Multiple]:
HD: 329.4392    S 35d22'50" W
Pick end point or enter Point Number:
HD: 334.2514    N 80d17'59" E
Int: 44°55'09"   Ext: 315°04'51"   Defl: 135°04'51"
« Reply #4 on: April 08, 2010, 10:10:49 AM »
Not really. It's the way the command selects the lines, I guess.
Command: _AeccCgAng
Second line:
The acute angle is 90.0900 (dms)
The obtuse angle is 269.5100 (dms)
I selected the white lines.
