Author Topic: [AutoCAD 2008] how to control locked layer display fading use AutoLISP  (Read 4090 times)
e2002
       As we known that the command "laylck" in AutoCAD 2008, it can fading display the locked layers . but the command "laylck" can't select multiple objects at once (wish the next version of AutoCAD will support).
      About 3 years ago , i written a lisp function do the same as the command "laylck" , it still works in AutoCAD 2008 very OK, but i find a fifference between my function and command "laylck" : if using "laylck" , then fading display OK, if use my function "lkpt:Layer:Lock" ,the layers locked , but fading display is not support . my programming with ActiveX , not use (entget) (entmod) ...
     I want to know , is AutoCAD 2008 supply a new lisp function to control the locked layer's fading display ? or any method to control this with LISP develop ?
    I posted this question on Autodesk Discussion Group ( http://discussion.autodesk.com/thread.jspa?threadID=554850 ),
one answer told me the new system variable "LAYLOCKFADECTL" , but i read the help file i found the system variable not the right answer. would anyone can tell me the right answer ?
« Last Edit: March 24, 2007, 03:25:20 AM by e2002 »
I sure can't find any way to enable the fading in ActiveX....I get the same results that you describe in my own function.
Crank
I've just read on the Spago forum that layer fade control requires regening.
Perhaps you should set REGENAUTO on.
whdjr
Why not use layiso.  It locks the layers that are faded so that you can't change them and it allows for multiple selection.
Hi there e2002,
The workaround until they get the COM API fixed is to set/reset the "LAYLOCKFADECTL" variable.
(defun c:lockLayers (/ activeDoc layList lays fadeSet)
  (setq activeDoc(vla-get-activedocument (vlax-get-acad-object)))
  (setq layList'("Layer1"));;<<<---do whatever to get the list you want locked
  (setq lays (vla-get-layers activeDoc))
 (mapcar '(lambda (x)
     (vla-put-lock (vla-item lays x) :vlax-true)
  laylist)
  (setq fadeSet(vla-getvariable activeDoc "LAYLOCKFADECTL"))
  (vla-setvariable activeDoc "LAYLOCKFADECTL" 0)
  (vla-setvariable activeDoc "LAYLOCKFADECTL" fadeSet)
« Last Edit: March 28, 2007, 11:18:57 AM by Jeff_M »
