As we known that the command "laylck" in AutoCAD 2008, it can fading display the locked layers . but the command "laylck" can't select multiple objects at once (wish the next version of AutoCAD will support).
About 3 years ago , i written a lisp function do the same as the command "laylck" , it still works in AutoCAD 2008 very OK, but i find a fifference between my function and command "laylck" : if using "laylck" , then fading display OK, if use my function "lkpt:Layer:Lock" ,the layers locked , but fading display is not support . my programming with ActiveX , not use (entget) (entmod) ...
I want to know , is AutoCAD 2008 supply a new lisp function to control the locked layer's fading display ? or any method to control this with LISP develop ?
I posted this question on Autodesk Discussion Group (
http://discussion.autodesk.com/thread.jspa?threadID=554850 ),
one answer told me the new system variable "LAYLOCKFADECTL" , but i read the help file i found the system variable not the right answer. would anyone can tell me the right answer ?
