Author Topic: Title Blocks Placement on the paper?  (Read 1519 times)
SDETERS
« on: August 29, 2007, 11:16:06 AM »
What is the appropriate location justification of title blocks on drawings?  What Margins is common
Should they centered on the sheet?
Should they be left bottom justified?
Rob...
Re: Title Blocks Placement on the paper?
« Reply #1 on: August 29, 2007, 11:18:11 AM »
When working with a set of drawings I usually center it vertically and justify right to leave room for binding strip at left.
CAD Tech
Guest
« Reply #2 on: August 29, 2007, 11:18:34 AM »
I've always done middle-right with about 1/2" white space along the right edge.  This will allow for a binding strip along the left edge and won't interfere with any linework you may have way out to the left.  You might find an "industry standard" way of doing this in Architectural Standards.
Arizona
« Reply #3 on: August 29, 2007, 11:18:50 AM »
This is what we use. Therefore when they are folded the titleblock shows easily.
David Hall
  • Automatic Duh Generator
« Reply #4 on: August 29, 2007, 11:19:33 AM »
what ^ he said, plus Margins are based on your plotter
« Reply #5 on: August 29, 2007, 11:21:28 AM »
Depends on the size of the titleblock...but I generally have the same space on the top, bottom, and right and the rest is on the left for binding.
SDETERS
« Reply #6 on: August 29, 2007, 11:31:33 AM »
tion
So different paper sizes have different title block justification?
What brought this up is the scale to paper size option when one prints from say a d size paper to 8.5 x 11 size paper.
When one does this the print gets scaled down to different sizes depending where I put the title block.  Unless I say center print on paper.
Good info
« Last Edit: August 29, 2007, 11:57:16 AM by SDETERS »
