Author Topic: Objects disappear on view port  (Read 3374 times)
« on: October 17, 2016, 10:47:37 AM »
We have a user that is setting up a cover sheet. She attaches an PDF file to use for a vicinity map in modelspace. Then creates a viewport on the cover sheet. But when she draws anything on top of the viewport it disappears. I don't have the same problem on my PC. *shrug*
Any thoughts? I'm stumped.
ChrisCarlson
Re: Objects disappear on view port
« Reply #1 on: October 17, 2016, 12:06:38 PM »
Is the PDF underlay shown in the paperspace layout? Drawing is funky as objects are created "above" the VP but immediately get placed behind the VP.
« Reply #2 on: October 17, 2016, 12:47:35 PM »
Yes, through the viewport. And Yes.
tedg
« Reply #3 on: October 17, 2016, 03:57:43 PM »
Does Draworder help? Set the viewport behind the PS graphics?
Windows 10 Pro 64bit, AutoCAD 2023, REVIT 2023
danallen
« Reply #4 on: October 17, 2016, 06:06:35 PM »
Is plot paperspace last set differently on each machine?
« Reply #5 on: October 18, 2016, 07:04:29 AM »
Nope!
« Reply #6 on: October 18, 2016, 07:04:51 AM »
Don't think so but i'll check one more time.
ChrisCarlson
« Reply #7 on: October 18, 2016, 08:04:01 AM »
That's pretty much how the PDF import was implemented. You may be able to set the transparency of the PDF to see the underlying lines. Beyond that you might need to draft in MS and CHSPACE it into PS, if truly needed.
« Reply #8 on: October 18, 2016, 08:47:37 AM »
But everything works fine on my PC. :)
ChrisCarlson
« Reply #9 on: October 18, 2016, 09:06:17 AM »
Setup the same?
« Reply #10 on: October 18, 2016, 09:09:31 AM »
Bryco
« Reply #11 on: October 18, 2016, 10:02:42 AM »
plot paperspace last?
« Reply #12 on: October 18, 2016, 10:37:19 AM »
yes.
but its not just in the plotting. When you draw anything on top of the view port it disappears. LOL
« Reply #13 on: October 18, 2016, 11:26:06 AM »
yes.
plot paperspace last was the problem.
Thanks!
Bryco
« Reply #14 on: October 18, 2016, 11:29:29 PM »
It must act as a draworder I guess. Glad to help.  I owe you and this site so much
