Author Topic: Scaling the nested entities of a block  (Read 4453 times)
ribarm
  • Marko Ribar, architect
Re: Scaling the nested entities of a block
« Reply #15 on: June 13, 2013, 12:25:26 PM »
(setq f (getdist "\nScale Factor: "))
(getdist) will always return positive real number, so to prevent entering 0.0, you need (initget 2), and to prevent entering ENTER - nil value, you need (initget 1)...
So instead of :
(initget 6)
I would suggest :
(initget 3)
And what if "INSERT" contains "INSERT" entities... I suppose child "INSERT" entities will be scaled, and then child entities of child "INSERT" will be scaled... Shouldn't you operate only on parent "INSERT" entities?
M.R. on Youtube
« Reply #16 on: June 13, 2013, 01:11:14 PM »
Command: (getdist "\nEnter a distance: ")
Enter a distance: -2
-2.0
...and to prevent entering ENTER - nil value, you need (initget 1)...
I don't want to prevent the user from pressing ENTER - hence the if statement.
By preventing ENTER there is no way for the user to exit the program without forcing an error with Esc
ribarm
« Reply #17 on: June 13, 2013, 01:55:10 PM »
OK Lee, so I left (initget 6)... Here is my modification for my second question - though not tested thoroughly...
  1. (defun c:scaleparentinsertsinside ( / ssparins e f i l n s )
  2.
  3.     (defun ssparins ( / blchk _reml ss sss i ins lst lstbl chbll parbll )
  4.
  5.       (defun blchk ( ins / en lst )
  6.         (setq en (tblobjname "BLOCK" (cdr (assoc 2 (entget ins)))))
  7.         (while (setq en (entnext en))
  8.           (if (eq (cdr (assoc 0 (entget en))) "INSERT")
  9.             (setq lst (cons (tblobjname "BLOCK" (cdr (assoc 2 (entget en)))) lst))
  10.           )
  11.         )
  12.         lst
  13.       )
  14.
  15.       (defun _reml (l1 l2 / a n ls)
  16.         (while
  17.           (setq n nil
  18.                 a (car l2)
  19.           )
  20.           (while (and l1 (null n))
  21.             (if (equal a (car l1) 1e-8)
  22.               (setq l1 (cdr l1)
  23.                     n t
  24.               )
  25.               (setq ls (append ls (list (car l1)))
  26.                     l1 (cdr l1)
  27.               )
  28.             )
  29.           )
  30.           (setq l2 (cdr l2))
  31.         )
  32.         (append ls l1)
  33.       )
  34.
  35.       (setq ss (ssget "_:L" '((0 . "INSERT"))))
  36.       (setq sss (ssadd) i -1)
  37.       (while (setq ins (ssname ss (setq i (1+ i))))
  38.         (setq lst (cons ins lst))
  39.       )
  40.       (foreach ins lst
  41.         (setq lstbl (cons (tblobjname "BLOCK" (cdr (assoc 2 (entget ins)))) lstbl))
  42.       )
  43.       (setq lstbl (acet-list-remove-duplicates lstbl nil))
  44.       (foreach ins lst
  45.         (foreach in (vl-remove ins lst)
  46.           (if (member (tblobjname "BLOCK" (cdr (assoc 2 (entget in)))) (blchk ins))
  47.             (setq chbll (cons (tblobjname "BLOCK" (cdr (assoc 2 (entget in)))) chbll))
  48.           )
  49.         )
  50.       )
  51.       (setq chbll (acet-list-remove-duplicates chbll nil))
  52.       (setq parbll (_reml lstbl chbll))
  53.       (foreach ins lst
  54.         (if (member (tblobjname "BLOCK" (cdr (assoc 2 (entget ins)))) parbll)
  55.           (ssadd ins sss)
  56.         )
  57.       )
  58.       sss
  59.     )
  60.
  61.     (if
  62.         (and
  63.             (progn
  64.                 (initget 6)
  65.                 (setq f (getdist "\nScale Factor: "))
  66.             )
  67.             (setq s (ssparins))
  68.         )
  69.         (repeat (setq i (sslength s))
  70.             (if (not (member (setq n (cdr (assoc 2 (entget (ssname s (setq i (1- i))))))) l))
  71.                 (progn
  72.                     (setq l (cons n l)
  73.                           e (tblobjname "block" n)
  74.                     )
  75.                     (while (setq e (entnext e))
  76.                         (vl-catch-all-apply 'vlax-invoke (list (vlax-ename->vla-object e) 'scaleentity '(0.0 0.0 0.0) f))
  77.                     )
  78.                 )
  79.             )
  80.         )
  81.     )
  82.     (command "_.regen")
  83.     (princ)
  84. )
  85.
M.R. on Youtube
Lupo76
« Reply #18 on: June 14, 2013, 02:03:22 AM »
I see that my question has sparked your creativity  :-) :-) :-) :-) :-) :-) :-) :-) :-) :-) :-D
