Author Topic: Scaling the nested entities of a block  (Read 4451 times)
Lupo76
« on: June 11, 2013, 12:30:33 PM »
Hello to all,
I searched the web but I could not find it.
Is there a lisp able to scale the entities nested inside a block, without using the block editor?
It would be nice that he could work with multiple blocks simultaneously.
Thanks in advance
Re: Scaling the nested entities of a block
« Reply #1 on: June 11, 2013, 01:16:21 PM »
You can modify the block definition.
Tharwat
  • Hypersensitive
« Reply #2 on: June 11, 2013, 01:50:07 PM »
Try this ...
  1. (defun c:Test (/ sc ss i sn en)
  2.   (if (and (setq sc (getdist "\n Specify The scale factor :"))
  3.            (setq ss  (ssget "_:L"  '((0 . "INSERT"))))
  4.       )
  5.     (repeat (setq i (sslength ss))
  6.       (setq sn (ssname ss (setq i (1- i))))
  7.       (setq en (tblobjname "BLOCK" (cdr (assoc 2 (entget sn)))))
  8.       (while (setq en (entnext en))
  9.         (if (eq (cdr (assoc 0 (entget en))) "INSERT")
  10.           (vl-catch-all-apply
  11.             'vla-scaleEntity
  12.             (list (vlax-ename->vla-object en)
  13.                   (vlax-3d-point (cdr (assoc 10 (entget en))))
  14.                   sc
  15.             )
  16.           )
  17.         )
  18.       )
  19.     )
  20.   )
  21.   (command "_.regen")
  22.   (princ)
  23. )
  24.
« Last Edit: June 11, 2013, 02:08:33 PM by Tharwat »
Lupo76
« Reply #3 on: June 12, 2013, 01:20:11 AM »
Yes, this I know, but I have hundreds of blocks "with name and different graphics" in the drawing.
And so I'm looking for a lisp to speed up this operation.
Lupo76
« Reply #4 on: June 12, 2013, 01:29:04 AM »
Try this ...
  2. ---- etc
  3. )
  4.
What should he do this lisp.
I've tried it in AutoCAD 2010 but did nothing  :-(
I try to better explain my need:
I have hundreds of blocks in the drawing "with name and different graphics", all included with scale in X, Y, Z = 1
I want to scale the contents of the blocks (nested objects inside them) to make sure that the insertion scale remains stable in X, Y, Z = 1.
Thank you all in advance for suggestions.
Marc'Antonio Alessi
  • Marco
« Reply #5 on: June 12, 2013, 02:57:02 AM »
Ti conviene allegare un esempio di un blocco "prima" e "dopo".
Se ho ben capito, devi scalare i blocchi annidati in un blocco?
Lupo76
« Reply #6 on: June 12, 2013, 03:11:24 AM »
Non devo scalare i "blocchi annidati dentro i blocchi", ma gli "oggetti annidati dentro i blocchi" senza scalare l'oggetto "blocco".
Nel file che ho allegato vedrai dei blocchi con scala di inserimento in X Y e Z pari a 10. Io vorrei che la grafica del blocco sia scalata 10 volte più piccola, ma che nel pannello delle proprietà venga riportata come scala di inserimento sempre 10.
Spero di essere stato chiaro.
Translate in english:
I do not have scale the "nested blocks in the blocks", but the "nested objects within blocks" without scaling the object "block."
In the file I attached you will see the blocks with insertion scale in XY and Z equal to 10. I wish that the graphics of the block is scaled 10 times smaller, but in the properties panel is reported as scale always added 10.
I hope I was clear.
Marc'Antonio Alessi
  • Marco
« Reply #7 on: June 12, 2013, 03:30:20 AM »
You must act as Tharwat (and CAB) have suggested.
Indeed the function of Tharwat does not work,
perhaps it needs some little modification...
I think Tharwat solution modify only nested blocks:
Try this ONLY as example not as solution:
         (vl-catch-all-apply
           'vla-scaleEntity
                 sc
 (command "_.regen")
[\code]
Tharwat
  • Hypersensitive
« Reply #8 on: June 12, 2013, 03:02:02 PM »
Try this ...
  2. ---- etc
  3. )
  4.
It does scale the nested blocks only .
Lupo76
« Reply #9 on: June 13, 2013, 01:13:59 AM »
Ok thank you all!
I solved it.
          (vl-catch-all-apply
            'vla-scaleEntity
                  (vlax-3d-point (list 0 0 0))
                  sc
  (command "_.regen")
I replaced replaced the line
with
and removed the type checking of entity.
Now is ok.
roy_043
  • BricsCAD 18
« Reply #10 on: June 13, 2013, 03:20:29 AM »
@ Lupo76:
There is a problem if the selection contains multiple inserts referencing the same block. That block will then be scaled multiple times...
Lupo76
« Reply #11 on: June 13, 2013, 03:22:44 AM »
it is true!
However in my case I do not have these situations.
No I never nested blocks ;-)
« Reply #12 on: June 13, 2013, 08:26:02 AM »
Note that roy was referring to multiple occurrences of the same block, not nested block references.
To avoid this problem, simply check whether the block definition has already been processed:
(defun c:test ( / e f i l n s )
        (and
                (initget 6)
                (setq f (getdist "\nScale Factor: "))
            (setq s (ssget "_:L" '((0 . "INSERT"))))
        (repeat (setq i (sslength s))
            (if (not (member (setq n (cdr (assoc 2 (entget (ssname s (setq i (1- i))))))) l))
                    (setq l (cons n l)
                          e (tblobjname "block" n)
                    (while (setq e (entnext e))
                        (vl-catch-all-apply 'vlax-invoke (list (vlax-ename->vla-object e) 'scaleentity '(0.0 0.0 0.0) f))
    (command "_.regen")
(vl-load-com) (princ)
Lupo76
« Reply #13 on: June 13, 2013, 10:23:51 AM »
Perfect!
Thank you!!!
« Reply #14 on: June 13, 2013, 10:25:43 AM »
You're welcome.  :-)
