Author Topic: I have a question about Blocks  (Read 4415 times)
lamarn
Re: I have a question about Blocks
« Reply #15 on: November 16, 2016, 02:18:34 PM »
It was a bold statement i made.. :devilsidesmile:
However, scaling imported linework to a - Guess the door width factor - to me really seems like a lack of proper data sets and communication. Probably legal issues get in the way To obtain better cad data.
Regards hans..
« Reply #16 on: November 16, 2016, 04:12:55 PM »
Unfortunately, more times than not, I am forced to scale the converted to CAD file using a hospital door and guessing the width of the door, by standard door widths for a certain type of door. I usually get it 'close' for our needs, such as figuring how much Network wire we need down hallways.
Sounds like a job I did that had at least 20 buildings in every state.
Sounds like they need the location of equipment and distance between and general idea of conditions(will route to run wire require a lift, is drop ceiling,  open warehouse, etc...)and is much cheaper to over estimate 20' to 30' of being off then to pay all the resources required to get a accurate set.
