Author Topic: [Help]Problem about "box_text".  (Read 4743 times)
cjw
« on: December 18, 2009, 12:23:34 AM »
;;;       +                   box_text                             +
;;;       +            Created by C. Alan Butler                   +
;;;       +               Copyright 2005                           +
;;;       +   by Precision Drafting & Design All Rights Reserved.  +
;;;       +    Contact at ab2draft@TampaBay.rr.com                 +
;;; VERSION
;;;  1.2 Jan 24, 2006  UCS corrections
;;; FUNCTION
;;;  Return Box coordinates for an dtext object in any UCS, any angle.
;;; USAGE
;;;  (box_text ent)
;;; ARGUMENTS
;;;  ent = text ename
;;;  RETURNS
;;;   list of 4 points for box,  (ll lr ur ul)
<edit: old code removed>
« Last Edit: December 18, 2009, 10:46:41 AM by CAB »
Re: [Help]Problem about "box_text".
« Reply #1 on: December 18, 2009, 01:41:38 AM »
Can you describe your problem.
is it that the smallest box is a different size for the horizontal text than the vertical text ?
cjw
« Reply #2 on: December 18, 2009, 04:00:38 AM »
see the dwg with shx file.
Maybe the "box_text" have not right work.
cjw
« Reply #3 on: December 18, 2009, 04:02:48 AM »
the horizontal text is OK.
the vertical text does not get right box points.
cjw
« Reply #4 on: December 18, 2009, 05:44:35 AM »
; Program Name: Text-Box.lsp [Text-Box R2]
; Created By:   Terry Miller (Email: terrycadd@yahoo.com)
; c:Text-Box -  Draws a polyline Text Box outlining Text, Mtext and Dimensions.
(defun c:TB () (c:Text-Box)) ;Shortcut
(defun c:Text-Box (/ Cnt# EntName^ Osmode# Pt PtsList@ SS&)
  (setq Osmode# (getvar "OSMODE"))
  (princ "\nSelect Text, Mtext or Dimension for Text Box")
  (if (setq SS& (ssget '((-4 . "<OR")
(0 . "TEXT")
(0 . "MTEXT")
(0 . "DIMENSION")
(-4 . "OR>")
      (command "UNDO" "BEGIN")
      (setvar "OSMODE" 0)
      (setq Cnt# 0)
      (repeat (sslength SS&)
(setq EntName^ (ssname SS& Cnt#))
(setq PtsList@ (append (Text-Box EntName^) (list "C")))
(command "PLINE" (foreach Pt PtsList@ (command Pt)))
(setq Cnt# (1+ Cnt#))
      ) ;repeat
      (command "UNDO" "END")
      (setvar "OSMODE" Osmode#)
    ) ;progn
    (princ "\nNo Text, Mtext or Dimension selected.")
  ) ;if
) ;defun c:Text-Box
; Text-Box - Function for Text, Mtext and Dimension entities
; Arguments: 1
;   Entity^ = Entity name of the Text, Mtext or Dimension to use
; Returns: A list of the four corners of the Text Box
(defun Text-Box (Entity^   /      Ang~      AngEntity~
Corners:  EntList@  EntNext^  EntType$ First
List@    MovePt    NewPts@   Pt Return@
Textboxes@      X        X1 X3
Y    Y1      Y3        Zero
; Corners: - Calculates the four corners of the Text Box
  (defun Corners: (Entity^ /    Ang~    Corners@    Dist~
   EntList@    Ins    Pt    Pt1    Pt2
   Pt3    Pt4
    (setq EntList@ (entget Entity^)
  Corners@ (textbox EntList@)
  Ang~    (cdr (assoc 50 EntList@))
  Ins    (cdr (assoc 10 EntList@))
  Pt    (mapcar '+ (car Corners@) Ins)
  Pt1    (polar Ins (+ Ang~ (angle Ins Pt)) (distance Ins Pt))
  Pt    (mapcar '+ (cadr Corners@) Ins)
  Pt3    (polar Ins (+ Ang~ (angle Ins Pt)) (distance Ins Pt))
  Dist~    (* (distance (car Corners@) (cadr Corners@))
      (cos (- (angle Pt1 Pt3) Ang~))
  Pt2    (polar Pt1 Ang~ Dist~)
  Pt4    (polar Pt3 Ang~ (- Dist~))
    ) ;setq
    (list Pt1 Pt2 Pt3 Pt4)
  ) ;defun Corners:
EntType$ (cdr (assoc 0 EntList@))
  ) ;setq
    ((= EntType$ "TEXT")
     (setq Return@ (Corners: Entity^))
    ) ;case
    ((or (= EntType$ "MTEXT") (= EntType$ "DIMENSION"))
     (command "UNDO" "MARK")
     (setq EntNext^ (entlast))
     (command "EXPLODE" Entity^)
     (if (= EntType$ "DIMENSION")
       (command "EXPLODE" (entlast))
     ) ;if
     (while (setq EntNext^ (entnext EntNext^))
       (if (= "TEXT" (cdr (assoc 0 (entget EntNext^))))
(setq Textboxes@
(append Textboxes@ (list (Text-Box EntNext^)))
       ) ;if
     ) ;while
     (command "UNDO" "BACK")
     (setq AngEntity~ (angle (nth 0 (nth 0 Textboxes@))
     (nth 1 (nth 0 Textboxes@))
   Zero       (list 0 0)
   First      t
     ) ;setq
     (foreach List@ Textboxes@
       (foreach Pt List@
(setq X (car Pt)
       Y (cadr Pt)
(if First
   (setq First nil
X1 X
Y1 Y
) ;if
(if (< X X1)
   (setq X1 X)
(if (< Y Y1)
   (setq Y1 Y)
       ) ;foreach
     ) ;foreach
     (if (or (< X1 0) (< Y1 0))
   ((and (< X1 0) (< Y1 0)) (setq MovePt (list X1 Y1)))
   ((< X1 0) (setq MovePt (list X1 0)))
   ((< Y1 0) (setq MovePt (list 0 Y1)))
) ;cond
(command "UCS" "M" MovePt)
       ) ;progn
     ) ;if
     (setq First t)
       (foreach Pt List@
(setq Ang~ (- (angle Zero Pt) AngEntity~))
(setq Pt (polar Zero Ang~ (distance Zero Pt)))
(setq X (car Pt)
       Y (cadr Pt)
(if First
   (setq First nil
X1 X
X3 X
Y1 Y
Y3 Y
) ;if
(if (< X X1)
   (setq X1 X)
(if (< Y Y1)
   (setq Y1 Y)
(if (> X X3)
   (setq X3 X)
(if (> Y Y3)
   (setq Y3 Y)
       ) ;foreach
     ) ;foreach
     (command "UCS" "W")
     (setq NewPts@ (list (list X1 Y1)
(list X3 Y1)
(list X3 Y3)
(list X1 Y3)
     (foreach Pt NewPts@
       (setq Ang~ (+ (angle Zero Pt) AngEntity~))
       (setq Return@ (append Return@ (list Pt)))
     ) ;foreach
    ) ;case
  ) ;cond
  Return@
) ;defun Text-Box
All right. It's OK.
« Reply #5 on: December 18, 2009, 05:48:43 AM »
:) .. and it's a different program :)
great that you found a solution. Alan (CAB) may be interested in your first post.
« Reply #6 on: December 18, 2009, 08:33:23 AM »
Sorry cjw I had not posted my updated routine.
Find the complete Text Box routine here: http://www.theswamp.org/index.php?topic=7003.msg86092#msg86092
The updated dText subroutine is in the 2.3 version in the link above. It was fixed in 2008.  :?
If no one complains I forget to update as I make changes to the routines.
;;;       +                   box_text                             +
;;; VERSION
;;;  1.3 Nov 26, 2008  Fixed Bug when text was rotated
hermanm
« Reply #7 on: December 18, 2009, 11:49:51 AM »
Very nice routine, Alan.:)
The "eye candy" of dialog box and different box types are superb, IMO.
Natch, I have my own home-grown command line version, but never took it anywhere close to yours.
Think I'll switch.:)
fwiw, here's how I did my boxtext:
;;;--------------------boxtext--------------------------------------
;;;  Author: Herman Mayfarth
;;;  Purpose: draws a lwpolyline rectangle to enclose a TEXT entity
;;;  Parameters: ename - entity name of TEXT entity
;;;              layer, color, ltype - what they say
;;;  External functions: dxf lwrect
(defun boxtext (ename layer color ltype / txtent tb p10 h ang1 delta p1 d1 boxang boxdia p3)
  (setq tb (textbox (entget ename))
        p10 (dxf 10 ename)
        h (dxf 40 ename)
        ang1 (dxf 50 ename)
        delta (/ h 2);adjust to suit
        p1 (polar p10 (+ (/(* 5 pi) 4) ang1) (* (sqrt 2) delta))
        d1 (+(caadr tb) (* 2 delta))
        boxang (atan (+ h (* 2 delta)) d1)
        boxdia (* (/ 1 (cos boxang)) d1)
        p3 (polar p1 (+ boxang ang1) boxdia)
  );setq
  (lwrect p1 p3 ang1 layer color ltype)
);boxtext
(defun dxf (code ent) (cdr (assoc code (entget ent))))
;;;-------------------------lwrect------------------------------------
;;; Purpose: draws a lightweight polyline rectangle
;;; Params: p1,p3 - WCS points at lower left & upper right corners
;;;         rotate - rotation angle of long axis in radians
;;;         layer, color, ltype what they say
;;; Returns: EAL of entity
(defun lwrect (p1 p3 rotate layer color ltype / d13 abox p2 p4)
  (setq  d13 (distance p1 p3)
         abox (- (angle p1 p3) rotate)
         p2 (polar p1 rotate (* (cos abox) d13))
         p4 (polar p1 (+ rotate (/ pi 2)) (* (sin abox) d13))
  (entmake (list '(0 . "LWPOLYLINE")
                 '(100 . "AcDbEntity")
                 '(100 . "AcDbPolyline")
                  (cons 6 ltype)
                  (cons 8 layer)
                  '(43 . 0)
                  (cons 62 color)
                  '(90 . 4)
                  (cons 10 p1)
                  (cons 10 p2)
                  (cons 10 p3)
                  (cons 10 p4)
                  '(70 . 1);closed pline - must follow G.C. 10s
);lwrect
& similarly for boxmtext
Thx for your very polished work.
stevesfr
« Reply #8 on: December 18, 2009, 12:21:27 PM »
;;;       +                   box_text                             +
;;; VERSION
OK, where do we find bt-single.sld???
Can't remember what I'm supposed to forget.
« Reply #9 on: December 18, 2009, 12:24:14 PM »
I think CAB forgot to upload it  :wink:
Here, for now:
http://www.theswamp.org/index.php?topic=4723.msg81560#msg81560
« Reply #10 on: December 18, 2009, 12:29:40 PM »
Sorry Steve, I change the lsp attachment to a zip with needed files.
Thanks Herman 8-)
stevesfr
« Reply #11 on: December 18, 2009, 12:45:07 PM »
Thanks Herman 8-)
Grabbed it, thanks... we'll have fun now !  maybe a green rectangle with a red ribbon i.e. a dynamic block?
love it !!!!
« Reply #12 on: December 18, 2009, 12:52:53 PM »
Thanks Lee, that was quick thinking. 8-)
myloveflyer
« Reply #13 on: December 18, 2009, 10:13:13 PM »
Thanks,CAB
a good reference for this program
Never give up !
« Reply #14 on: December 19, 2009, 07:12:42 AM »
No problem, I only saw the program the other day - I must say - fantastic work Alan, as usual.
