Author Topic: Auto Circle Placement . . .  (Read 2087 times)
MSTG007
« on: May 11, 2017, 07:03:26 AM »
Another wonderful morning and another crazy question. Im curious if there is a way that I can get a circle drawn in between 2 parallel lines or polylines? something like this |o|. So if there are several hundreds of these parallel lines, it could place a circle in the middle of them.
If not possible, it was sure worth the question. Thanks guys, have a great day!
Civil3D 2020
ChrisCarlson
Re: Auto Circle Placement . . .
« Reply #1 on: May 11, 2017, 07:48:38 AM »
It's really just a circle between two points. Select line1, select line2, wambam circle.
« Reply #2 on: May 11, 2017, 10:20:49 AM »
Try this:
  1. (defun c:foo (/ a b d i p ss x)
  2.   ;; RJP - 05.11.2017
  3.   ;; Places circles between parallel lines and 2 pt polylines
  4.   ;; Not the fastest code in the world, but faster than doing by hand :P
  5.   (if (and (setq ss (ssget '((-4 . "<OR")
  6.                              (0 . "line")
  7.                              (-4 . "<AND")
  8.                              (0 . "lwpolyline")
  9.                              (90 . 2)
  10.                              (-4 . "AND>")
  11.                              (-4 . "OR>")
  12.                             )
  13.                     )
  14.            )
  15.            (setq d (getdist "\nEnter MAX distance to search: "))
  16.       )
  17.     (progn
  18.       (setq ss
  19.              (mapcar
  20.                '(lambda (x)
  21.                   (list
  22.                     (angle (setq a (vlax-curve-getstartpoint x)) (setq b (vlax-curve-getendpoint x)))
  23.                     (polar a (angle a b) (* 0.5 (distance a b)))
  24.                     x
  25.                   )
  26.                 )
  27.                (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss)))
  28.              )
  29.       )
  30.       (while (setq i (car ss))
  31.         (setq ss (cdr ss))
  32.         (mapcar
  33.           '(lambda (x)
  34.              (and
  35.                (<= (distance (cadr i) (setq p (vlax-curve-getclosestpointto (last x) (cadr i)))) d)
  36.                (or (equal (car i) (car x) 1e-8) (equal (+ pi (car i)) (car x) 1e-8))
  37.                (entmakex
  38.                  (list
  39.                    '(0 . "circle")
  40.                    (assoc 8 (entget (last i)))
  41.                    (cons
  42.                      10
  43.                      (polar (cadr x) (angle (cadr x) (cadr i)) (* 0.5 (distance (cadr x) (cadr i))))
  44.                    )
  45.                    (cons 40 (* 0.5 (distance p (vlax-curve-getclosestpointto (last i) p))))
  46.                  )
  47.                )
  48.                ;; (setq ss (vl-remove x ss))
  49.              )
  50.            )
  51.           ss
  52.         )
  53.       )
  54.     )
  55.   )
  56.   (princ)
  57. )
« Last Edit: May 12, 2017, 09:27:35 AM by ronjonp »
MSTG007
« Reply #3 on: May 11, 2017, 02:13:36 PM »
lol. That is sweet. Do you think they can do it in a row? All in all that is awesome stuff Ron. (As usual)!
Civil3D 2020
« Reply #4 on: May 11, 2017, 02:18:24 PM »
Comment out line 49 (setq ss (vl-remove x ss)) :)
« Last Edit: May 11, 2017, 02:21:38 PM by ronjonp »
Atook
  • AKA Tim
« Reply #5 on: May 11, 2017, 02:47:04 PM »
Ninja!
« Reply #6 on: May 11, 2017, 02:58:23 PM »
MSTG007
« Reply #7 on: May 11, 2017, 04:53:38 PM »
just got to dive into this bad boy. I hope I have OE errors on my part. lol. Anyways that's usually what it is. This is the drawing I am working with polylines evenly spaced.
Civil3D 2020
« Reply #8 on: May 11, 2017, 11:30:11 PM »
You should post a sample drawing with all of your questions. That's a bit more involved than |0|... *edit* actually simple if you just array the circle.
« Last Edit: May 11, 2017, 11:34:20 PM by ronjonp »
MSTG007
« Reply #9 on: May 12, 2017, 08:07:43 AM »
You right. Sorry. Usually I come up with the idea and then go.. .wait can it do this. My wonderful mind is no conventional. lol. I saw that, and said, that be cool if you could select a bunch of stalls and it puts circles in there for counting. But still I do like what you came up with! Great job.
Civil3D 2020
« Reply #10 on: May 12, 2017, 09:26:13 AM »
No worries .. just saying the more info you provide in the initial question, the more likely you'll get an answer that suits your needs.  :)
alanjt
  • Standby for witty remark...
« Reply #11 on: May 12, 2017, 09:31:20 AM »
Slick!
Dropbox
« Reply #12 on: May 12, 2017, 09:34:04 AM »
