Author Topic: layerdirector : help with external reference  (Read 4337 times)
lamarn
« on: September 17, 2012, 03:46:37 AM »
I use Lee mac's layerdirector. It works great, but i would like this routine to handle my xref objects as well.
The thing is i do not know how object 'external reference' is called upon lisp-wise.
Does anyone know how this can be done?
See beneath part of the code.
(setq *LayerDirector-LayerData*
        ("[DM]TEXT,TEXT"   "TEXT"      )
        ("DIM*,*LEADER"    "DIMENSIONS")
        ("*VPORT*"         "DEFPOINTS" )
        ("*?? name for xrefs ??*  "XREF")
http://www.lee-mac.com/lisp/html/LayerDirectorV1-1.html
Design is something you should do with both hands. My 2d hand , my 3d hand ..
roy_043
  • BricsCAD 18
Re: layerdirector : help with external reference
« Reply #1 on: September 17, 2012, 04:32:02 AM »
If you analyse the code you will find that Lee has added a "Print Command Debug Mode".
If you change:
  1. (setq *PrintCommand* nil)
To:
  1. (setq *PrintCommand* T)
You will be able to find the commands you are looking for.
And with these commands you can create your own sublist to add to *LayerDirector-LayerData*:
  1. ("*XREF"  "XREF")
The first part of the sublist is a wcmatch string that matches one or more command names.
« Last Edit: September 17, 2012, 04:43:01 AM by roy_043 »
« Reply #2 on: September 17, 2012, 06:26:16 AM »
Thank you for assisting roy, I appreciate it  :-)
lamarn
« Reply #3 on: September 18, 2012, 05:25:35 PM »
Thank you!
Birdy
« Reply #4 on: June 07, 2013, 06:45:11 PM »
Lee;
testing this out, and I cannot seem to get the Layer Data to work for Color and other Layer properties when the layer does not exist in the drawing.
what is the format in the layer data list for properties other than layer name?
« Reply #5 on: June 07, 2013, 06:52:30 PM »
Lee;
Hi Jim,
Unfortunately layer properties are not supported in the current version of the program; the Layer Data list requires only a command name pattern and associated layer name to be set when the command name is matched. If I get some spare time, I may look to update the program to incorporate other layer properties in this list.
Lee
Birdy
« Reply #6 on: June 07, 2013, 07:07:17 PM »
That's cool.
It works great in our template where all the layers exist.
Very nice work Lee. You continually amaze me.  :-)
« Reply #7 on: June 07, 2013, 11:16:37 PM »
Birdy
« Reply #8 on: June 08, 2013, 09:55:13 AM »
Thanks CAB, I will check that one out.
« Reply #9 on: June 09, 2013, 12:36:06 PM »
That's cool.
Thanks Jim, I appreciate your compliments  :-)
lamarn
« Reply #10 on: July 17, 2015, 05:19:53 AM »
I made three videos on YouTube to explain the advantages of lm:layerdirector. Search for them on YouTube. I made them to help me and hopefully others with layering bs. Works
« Reply #11 on: July 17, 2015, 09:03:22 AM »
Thank you Hans! - Your videos are excellent  :-)
lamarn
« Reply #12 on: December 03, 2015, 05:06:13 AM »
Lee,
Thanks for updating the code to v1.3. Excellent work!
These aditional options are very welcome.
http://www.lee-mac.com/layerdirector.html
I have a little question.
Say i want to use my own command to work with layer director. How can this be made possible?
defun c:1
command : pline
« Last Edit: January 13, 2016, 04:37:12 PM by lamarn »
lamarn
« Reply #13 on: January 13, 2016, 04:36:42 PM »
Mr. Lee Mac updated the code (v1.4) and i am happy  :2funny: to find that now it is more than easy to apply layerdefinitions to custom commands.
https://youtu.be/ZSDbiZgHGnI
Example, not the most sifit
layerdirector:data
;;  Command Pattern  |  Layer Name    |       Description       |    Colour    |   Linetype   |    Lineweight    |       Plot       |    Plot Style    ;;
;;     [string]      |   [string]     |         [string]        | 0 < int <256 |   [string]   | -3 = Default     |  1 = Will Plot   |     [string]     ;;
;;                   |                |     Use "" for none     |              |              |  0 <= int <= 211 |  0 = Won't Plot  |  Use nil for CTB ;;
 ;; e.e.a. zoals  NLCS stijl
("[DM]TEXT,TEXT"    "X-XX_txt__"    "NLCS text"    7 "Continuous"    25 1 nil ) ; text
("DIM*"            "X-XX_dim_" "NLCS dimension" 7 "Continuous"  25 1 nil ) ; dims
("*VPORT*"          "vports" "NLCS viewport" 9 "Continuous" 13 0 nil ) ; vport
("*LEADER*"        "X-XX_ldr_" "NLCS leader" 7 "Continuous" 25 1 nil) ; leader
("*XLINE*"          "X-XX_hulplijn_" "NLCS hulp" 6 "Continuous" 13 0 nil) ; xlines
("*RAY*"            "X-XX_hulplijn_"  "NLCS hulp" 6 "Continuous" 13 0 nil) ; ray
("*XREF*"          "xref" "NLCS xref" 7 "Continuous" -3 1 nil) ; references
("*WIPEOUT*"        "X-XX_wipeout" "NLCS wipeout" 7 "Continuous" 13 1 nil) ; for wipeouts
("*HATCH*"          "X-XX_hatch-AD" "NLCS hatch" 253 "Continuous" 18 1 nil) ; for hatches
("*image*"          "X-XX_image_" "NLCS image" 7 "Continuous" 13 1 nil) ; for images
("*3dface*"        "_3D_face_"     "3D face"  4 "Continuous" 35 1 nil) ; faces
("*EXTRUDE*"      "_3D_solid_extrude_" "3D extrude" 4 "Continuous" 35 1 nil) ; extrude
("*REVOLVE*"        "_3D_solid_revolve_"  "3D revolve" 4 "Continuous" 35 1 nil)      ; revolved
("*SWEEP*"          "_3D_solid_sweep_"    "3D sweep" 3 "Continuous" 35 1 nil)      ; sweeps
("*LOFT*"          "_3D_solid_loft_"    "3D loft" 3 "Continuous" 35 1 nil)      ; sweeps
("*POLYSOLID*"          "_3D_solid_poly_"    "3D poly" 3 "Continuous" 35 1 nil)      ; sweeps
("*section*"          "_3D_section__"    "3D section" 125 "Continuous" 25 0 nil)      ; sections
("*sectionplane*"       "_3D_sectionplane__"    "3D sectionplane" 114 "Continuous" 25 0 nil)      ; sectionplane
; custom command  === > HERE IS WHERE THE REAL MAGIC HAPPENS .. :)
("DNH"        "X-XX_dim_DNH"    "none-NLCS DNH hoogtemaatvoering"    7 "Continuous" 18 1 nil)
("DNHmm"        "X-XX_dim_DNH"    "none-NLCS DNH hoogtemaatvoering"    7 "Continuous" 18 1 nil)
("DNHm"        "X-XX_dim_DNH"    "none-NLCS DNH hoogtemaatvoering"    7 "Continuous" 18 1 nil)
("inladenblock" "X-XX_dim_DNH" "none-NLCS DNH hoogtemaatvoering" 7 "Continuous" 18 1 nil)
("4PS"        "_3D_4-point-solid_"    "none-NLCS 4-point solid"    7 "Continuous" 18 1 nil)
("talud"      "talud" "none-NLCS talud" 1 "Continuous" 18 1 nil)
("0"        "0"    "none-NLCS" 7 "Continuous" 18 1 nil)
("1"        "1"    "none-NLCS" 1 "Continuous" 18 1 nil)
("1d"        "1d"    "none-NLCS" 1 "DOT5" 18 1 nil)
("1h"        "1h"    "none-NLCS" 1 "HIDDEN5" 18 1 nil)
("1c"        "1c"    "none-NLCS" 1 "CENTER2" 18 1 nil)
("1a"        "1"    "none-NLCS" 1 "DASHDOT2" 18 1 nil)
("2"        "2"    "none-NLCS" 2 "Continuous" 25 1 nil)
("2h"        "2h"    "none-NLCS" 2 "HIDDEN5" 25 1 nil)
("2c"        "2c"    "none-NLCS" 2 "CENTER2" 25 1 nil)
("2a"        "2a"    "none-NLCS" 2 "DASHDOT2" 25 1 nil)
("3"        "3"    "none-NLCS" 3 "Continuous" 35 1 nil)
("3h"        "3h"    "none-NLCS" 3 "HIDDEN5" 35 1 nil)
("3c"        "3c"    "none-NLCS" 3 "CENTER2" 35 1 nil)
("3a"        "3a"    "none-NLCS" 3 "DASHDOT2" 35 1 nil)
("4"        "4"    "none-NLCS" 4 "Continuous" 50 1 nil)
("4d"        "4h"    "none-NLCS" 4 "DOT5" 50 1 nil)
("4h"        "4h"    "none-NLCS" 4 "HIDDEN5" 50 1 nil)
("4c"        "4c"    "none-NLCS" 4 "CENTER2" 50 1 nil)
("4a"        "4a"    "none-NLCS" 4 "DASHDOT2" 50 1 nil)
("5"        "5"    "none-NLCS" 5 "Continuous" 70 1 nil)
("6"        "6"    "none-NLCS" 6 "Continuous" 100 1 nil)
("7"        "7"    "none-NLCS" 7 "Continuous" 25 1 nil)
("8"        "8"    "none-NLCS" 8 "Continuous" 25 1 nil)
("9"        "9"    "none-NLCS" 9 "Continuous" 25 1 nil)
("10"        "10"    "none-NLCS" 10 "Continuous" 25 1 nil)
("252"        "252"    "none-NLCS" 252 "Continuous" 18 1 nil)
("253"        "253"    "none-NLCS" 253 "Continuous" 18 1 nil)
("254"        "254"    "none-NLCS" 254 "Continuous" 18 1 nil)
     ;etc. etc.. apply a layer to your custom command...
(DEFUN C:LaC ( / )
  (setvar "cmdecho" 0)
  (princ "\nChange entities to current layer: ")
  (SETQ SS1 (SSGET))
  (command "_.chprop" SS1 "" "_layer" (getvar "clayer") "")
  (COMMAND "CHANGE" SS1 "" "PROP" "co" "bylAYER" "")
  (setvar "cmdecho" 1)
(defun c:0 () (c:lac) (princ))
(defun c:1 () (c:lac)  (princ))
(defun c:2 () (c:lac)  (princ))
etc. etc.
