Author Topic: add XDATA on simple rectangle  (Read 2956 times)
Andrea
« on: December 01, 2006, 02:57:21 PM »
Hi all..
i'm trying to add an information on simple rectangle...
(setq i1 (entget (car (entsel))))
(setq idata (list (list -3 (list "test1"
            (cons 1000 "test2")
(setq i1 (append i1 idata))
(entmod i1)
this seem to work.....but not true...
because if i re-select the same rectangle buy using...
it return me all the data without the new XDATA added...
seem that entmod is not working...
do i'm right ?
Keep smile...
Re: add XDATA on simple rectangle
« Reply #1 on: December 01, 2006, 03:45:59 PM »
Try this to get the XDATA:
(setq i1 (entget (car (entsel)) '("*")))
Patrick_35
« Reply #2 on: December 01, 2006, 04:34:37 PM »
Why you don't use Vla-SetXData Mon_Rectangle
SetXData (XDataType, XDataValue)
Andrea
« Reply #3 on: December 01, 2006, 10:01:48 PM »
Thanks PAT...
but,.....can you give me an example ?
Thanks Jeff....but what "*" mean ?  search all Xdata for the selected item ?
Keep smile...
« Reply #4 on: December 02, 2006, 12:51:46 AM »
get the dxf xdate straight in your head before you venture into the ActiveX version ..
In Jeff's code the '("*") represents return ALL Xdata Application Names
in your case you could use
(setq i1 (entget (car (entsel)) '("test1")))
since "test1" was your xdata APPName
Have a play with something like these to learn ...
(defun put-xdata (appName Data / elst exdata)
   ;; codehimbelonga kwb@theSwamp
    (regapp appName)
    (setq elst   (entget (car (entsel "\nSelect graphical entity: ")))
          exdata (list (list -3 (cons appName Data)))
          elst   (append elst exdata)
    (entmod elst)
(defun c:put-xdata1 (/ )
    (setq entityList (put-xdata "TEST-APPLICATION-NAME" (list (cons 1000 "Test Data"))))
(defun c:put-xdata2 (/ )
    (setq entityList (put-xdata "TEST-APPLICATION-NAME" (list (cons 1070 2))))
(defun c:put-xdata3 (/ )
                                (list
                                      (cons 1000 "DataList3")
                                      (cons 1002  "{")
                                      (cons 1070 3)
                                      (cons 1000 "Test String 3")
                                      (cons 1002  "}")
(defun c:put-xdata4 (/)
                                (list
                                      (cons 1000 "DataList4")
                                      (cons 1002  "{")
                                      (cons 1070 4)
                                      (cons 1000 "Test String 4 ")
                                      (cons 1002  "}")
                                     (cons 1000 "DataList4a")
                                      (cons 1002  "{")
                                      (cons 1070 44)
                                      (cons 1000 "Test String 4a")
                                      (cons 1002  "}")
(defun get-xdata (appName / myData)
    (setq myData
             (cadr
                 (assoc
                     -3
                     (entget
                         (car
                             (entsel
                                 "\nSelect graphical entity to extract Data : "
                         (list appName )
    myData
(defun c:get-xdata (/ )
    (setq entityData (get-xdata "TEST-APPLICATION-NAME" ))
(defun c:get-ACADxdata (/ )
    ;; for dimensions, etc
    (setq entityData (get-xdata "ACAD" ))
(defun c:get-ALLxdata (/ )
    (setq entityData (get-xdata "*" ))
Patrick_35
« Reply #5 on: December 02, 2006, 03:52:33 PM »
You have an answer here
« Reply #6 on: December 06, 2006, 05:36:12 AM »
And once you've assimilated the posts above, Have a look here ...
http://www.theswamp.org/index.php?topic=4395.msg53028#msg53028
Andrea
« Reply #7 on: December 06, 2006, 02:00:34 PM »
Thanks guys,,,, :-)
Keep smile...
