Author Topic: XData question  (Read 12331 times)
XData question
« on: February 06, 2006, 12:46:53 PM »
I'm trying to learn more about XData.  So I was thinking I would write a little routine that did a polyline, then then associated xdata to it.  Could be cool to associate room information to a room to generate a schedule.  I can't seem to get it right.  Can anyone help me with this.  It seems to put the xdata there, but I can't retrive it after.  The error I get is
; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on unknown exception
when running "MyGetXData".  Here is the code so far (still working on it).
(defun c:RoomInfo (/ ActDoc StPt Pt PtList CoordList PolyObj CodeList DataList CodeNum)
(defun MySetXData (Obj CodeList DataList / )
; Sets XData to an object.  Must number in code list must be 1001
(vla-SetXData Obj
 (vlax-make-variant
  (vlax-safearray-fill
   (vlax-make-safearray
    vlax-vbInteger
    (cons 0 (1- (length CodeList)))
   CodeList
 (vlax-make-variant
    vlax-vbVariant
    (cons 0 (1- (length Datalist)))
   DataList
(defun MyGetXData (Obj DataName / CodeType DataType)
; Retrive XData for an object
(vla-GetXData
 Obj
 (if DataName
  DataName
 'CodeType
 'DataType
(if (and CodeType DataType)
 (mapcar
  '(lambda (a b)
   (cons a (variant-value b))
  (safearray-value CodeType)
  (safearray-value DataType)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-StartUndoMark ActDoc)
(while
 (if StPt
  (setq Pt (getpoint StPt "\n Select next point: "))
  (setq Pt (getpoint "\n Select first point of polygon: "))
 (if (not StPt)
  (setq StPt Pt)
 (setq PtList (cons Pt PtList))
 (if (> (length PtList) 1)
  (grdraw (cadr PtList) (car PtList) 1)
(grdraw (car PtList) StPt 1)
(foreach Pt PtList
 (setq CoordList (cons (cadr Pt) CoordList))
 (setq CoordList (cons (car Pt) CoordList))
(setq PolyObj
 (vlax-invoke
  (vlax-get
   ActDoc
   (if (equal (getvar "cvport") 1)
    'PaperSpace
    'ModelSpace
  'AddLightweightPolyline
  CoordList
(vla-put-Closed PolyObj :vlax-true)
(setq CodeList '(1001))
(setq DataList '("MyRoomInformation"))
(setq CodeNum 1000)
(foreach Question '("Room name: " "Room number: ")
 (if (/= (setq tmpStr (getstring T (strcat "\n " Question))) "")
  (setq
   CodeList (cons CodeNum CodeList)
   DataList (cons tmpStr DataList)
   CodeNum
    (if (equal CodeNum 1000)
     (+ 2 CodeNum)
     (1+ CodeNum)
(setq CodeList (cons 1040 CodeList))
(setq DataList (cons (vlax-get PolyObj 'Area) DataList))
(MySetXData PolyObj (reverse CodeList) (reverse DataList))
(MyGetXData PolyObj nil)
If you comment out the line "(MyGetXData PolyObj nil)" then it won't error, but I can't retrive the xdata information.
Thanks in advance.
LE
Re: XData question
« Reply #1 on: February 06, 2006, 01:43:17 PM »
Tim;
This is not a direct answer and coming from someone that have use this two functions just once... I will simple post how I have done it, hope that would help.
(defun vlax-make-array-type  (lst atype)
      atype
      (cons 0 (1- (length lst))))
    lst))
(defun fractional-dim  (obj str)
  (vla-setxdata
    obj
    ;; XDataType as Variant (array of short)
    (vlax-make-array-type
      (list 1001 1000 1002 1070 1000 1070 1070 1002)
      vlax-vbinteger)
    ;; XData as Array of Variant
      (list
(vlax-make-variant "ACAD" vlax-vbstring)
(vlax-make-variant "DSTYLE" vlax-vbstring)
(vlax-make-variant "{" vlax-vbstring)
(vlax-make-variant 3 vlax-vbinteger)
(vlax-make-variant str vlax-vbstring)
(vlax-make-variant 277 vlax-vbinteger)
(vlax-make-variant 5 vlax-vbinteger)
(vlax-make-variant "}" vlax-vbstring))
      vlax-vbvariant)))
And I think to get the values, something like:
(vla-GetXData obj "myAPPNAME" 'XDataType 'XDataValue)
Then just explore the values of those two new variables....
If is a 'safearray' use (setq XDataType (vlax-safearray->list XDataType)) for both vars
Then, in your mapcar check if it is a variant and safearray and do the conversion the first with vlax-variant-value and the other using vlax-safearray->list and place them into your resultant list
Hope that the above makes some sense...
LE
Re: XData question
« Reply #2 on: February 06, 2006, 02:07:29 PM »
BTW,
There is one function to get xdata... in the www.acadx.com site
HTH
Re: XData question
« Reply #3 on: February 06, 2006, 02:26:23 PM »
Luis,
First off, Thanks for posting.
Yours does work, and I can get the xdata with my function after.  Do you remember why you set it up that way?  Is it required by AutoCAD?  I have looked through the help files, and have not had success with finding what I'm looking for, which is mostly my fault, as I don't know exactly what that may be.
My code seems to work if you only enter one bit of information, but if you enter information for both prompts, then it won't attach any xdata to the object.
BTW,
HTH
I just looked at their code, and it is close to what I have already, and it seems mine works okay because it returned the xdata that your routine attached.  Thanks for the link though.
I will continue to try and see what I'm doing wrong.  I hope I don't have to set it up the way you did.  I'm hoping that it can be a little more flexible.
Re: XData question
« Reply #4 on: February 06, 2006, 02:32:52 PM »
Tim, a part of the problem in yours is this:
(setq
   CodeNum
     (+ 2 CodeNum)
     (1+ CodeNum)
This sets CodeNum to 1002 which is the code for a Control String. From the help: "An extended data control string can be either “{”or “}”. " Keep the CodeNum at 1000 for strings.
FWIW, your code runs without error in 2006, but only the first 2 items in the list get written:
((1001 . "MyRoomInformation") (1000 . "master"))
Re: XData question
« Reply #5 on: February 06, 2006, 02:39:17 PM »
Thanks Jeff.  I thought that might be the problem, but I tried setting the codes 1001 1000 1002 and then having the first prompt put in the information at 1003, but that didn't work either.  I was going off this from the help.
1000–1009
 String (same limits as indicated with 0–9 code range)
1010–1059
 Double-precision floating-point value
1060–1070
 16-bit integer value
1071
 32-bit integer value
And then I saw this, so I changed it a little, still with no luck.
1000
 ASCII string (up to 255 bytes long) in extended data
1001
 Registered application name (ASCII string up to 31 bytes long) for extended data
1002
 Extended data control string ("{" or "}")
1003
 Extended data layer name
1004
 Chunk of bytes (up to 127 bytes long) in extended data
1005
 Entity handle in extended data; text string of up to 16 hexadecimal digits
Are there different numbers I can use? or do I have to just use 1000 for all my strings?  I was hoping that each entry could have it's own number, so that way I would know what each one was.
Thanks again Jeff and Luis.
Re: XData question
« Reply #6 on: February 06, 2006, 03:43:32 PM »
AFAIK you must use 1000 for all normal strings.  However, to be able to determine what is what, use multiple 1000 codes....for instance:
(setq roomnum "23"
      roomname "MasterBedroom"
      sqft 240.00)
(setq roomlist (list '(1000 . "RoomNumber")
     (cons 1000 roomnum)
     '(1000 . "RoomName")
     (cons 1000 roomname)
     '(1000 . "SquareFeet")
     (cons 1040 sqft)
(cdadr (member '(1000 . "RoomName") roomlist))
will return this:
"MasterBedroom"
Re: XData question
« Reply #7 on: February 06, 2006, 05:00:29 PM »
If that is the only way, then this is the code I will be using, for now at least.  Thanks again.
; Attach information to a poly that is drawn within the routine.
; v0.01
(vla-SetXData Obj
 (vlax-make-variant
    vlax-vbInteger
   CodeList
 (vlax-make-variant
    vlax-vbVariant
   DataList
(vla-GetXData
 Obj
 (if DataName
  DataName
 'CodeType
 'DataType
 (mapcar
  '(lambda (a b)
(while
 (if StPt
 (if (not StPt)
  (setq StPt Pt)
(foreach Pt PtList
(setq PolyObj
 (vlax-invoke
  (vlax-get
   ActDoc
    'PaperSpace
    'ModelSpace
  CoordList
(setq CodeNum 1000)
(foreach Question '("ROOM NAME" "ROOM NUMBER")
 (if (/= (setq tmpStr (getstring T (strcat "\n " Question ": "))) "")
  (setq
   DataList (cons Question DataList)
(setq CodeList (cons 1000 CodeList))
(setq DataList (cons "AREA" DataList))
;(print (MyGetXData PolyObj nil)) ; To make sure it got put there.
Peter Jamtgaard
Re: XData question
« Reply #8 on: February 07, 2006, 07:51:25 AM »
I created a couple functions for using xdata, and the easiest way I could think of was to use an xdata to list and list to xdata schema, I also included my standard errortrap function see below.
(setxdata obj (list (list "App1" 1 "Hello")(list "App2" "World" 2)))
would create the App1 and App2 registered applications and store the other items as xdata on the object.
Then
(getxdata obj) would return
'(("App1" 1 "Hello")(list "App2" "World" 2)))
much the same way ldata works
Peter
; The setxdata function will add a list of sublists to an object as xdata.
; The first item in each sublist is a unique string application name
(defun SetXData (objSelection lstOfSubLists / DataItem lstData
                 intDataType lstOfSublistsDXFCodes lstOfSublistsValues
                 safDXFCodes safDataValues)
 (if debug (princ "\nSetXdata: "))
 (if (= (type objSelection) 'ENAME)
  (setq objSelection (vlax-ename->vla-object objSelection))
 (foreach lstData lstOfSublists
  (setq lstOfSublistsDXFCodes (cons 1001 lstOfSublistsDXFCodes)
        lstOfSublistsValues   (cons (car lstData) lstOfSublistsValues))
  (RegApp (car lstData))
  (foreach DataItem (cdr lstData)
   (cond    ; Determine the data type and corrusponding DXF Code
    ((= (type DataItem) 'INT)
     (if (> DataItem 100000)
      (setq intDataType  1071)                          ; Long    Data Type
      (setq intDataType  1070)                          ; Integer Data Type
    ((= (type DataItem) 'REAL)(setq intDataType  1040)) ; Real Data Type
    ((= (type DataItem) 'STR)
     (if (or (= DataItem "{")(= DataItem "}"))          ; String Data Type
      (setq intDataType  1002)
      (setq intDataType  1000)
   (setq lstOfSublistsDXFCodes (cons intDataType lstOfSublistsDXFCodes)
         lstOfSublistsValues   (cons DataItem    lstOfSublistsValues)
 (setq safDXFCodes   (listToSafearray vlax-vbinteger
                      (reverse lstOfSublistsDXFCodes))
       safDataValues (listToSafeArray vlax-vbvariant
                      (reverse lstOfSublistsValues)))
 (errortrap '(vla-setXData objSelection safDXFCodes safDataValues)))
; Returns a list of sublists that include a application name as the first
; Item in every sublist and data for the remaining members
(defun C:GetXdata ()
 (getxdata (car (entsel "\nSelect object with Xdata: ")))
(defun GetXdata (objSelection / intCount lstAll lstSub safDXFValues safDXFValues)
;  (print strXdata)  (if DEBUG (print "GetXdata"))
 (vla-getxdata objSelection "" 'safDXFCodes 'safDXFValues)
 (if (and safDXFCodes
          safDXFValues
   (setq lstDXFCodes  (vlax-safearray->list safDXFCodes)
         lstDXFValues (mapcar 'variant-value (vlax-safearray->list safDXFValues))
         intCount 0
   (foreach intDXFCode lstDXFCodes
    (if (= intDXFCode 1001)
     (if lstSub
      (setq lstAll (cons (reverse lstSub) lstAll)
            lstSub (list (nth intCount lstDXFValues))
      (setq lstSub (list (nth intCount lstDXFValues)))
     (setq lstSub (cons (nth intCount lstDXFValues) lstSub))
    (setq intCount (1+ intCount))
   (if lstSub (reverse (cons (reverse lstSub) lstAll)))
; Standardized Error Trap
(defun ErrorTrap (symFunction / objError result)
 (if (vl-catch-all-error-p
      (setq objError (vl-catch-all-apply
                     '(lambda (X)(set X (eval symFunction)))
                      (list 'result))))
   (if DEBUG
     (princ "\n")
     (princ (vl-catch-all-error-message objError))
     (princ "\nWhile evaluating the expression: ")
     (princ symfunction)
     (princ "\n")
   nil
  (if result result 'T)
GDF
Re: XData question
« Reply #9 on: February 07, 2006, 09:02:43 AM »
Here is two routines I found for getting the xdata:
(defun C:XDL1 (/ BMENT BMSEL ELST FOROBJ)
 (setq BMSEL (entsel "\n* Select Object to Get It's Xdata *"))
 (if BMSEL
   (setq BMENT (car BMSEL))
   (vlax-for FOROBJ (vla-get-registeredapplications
                     (vla-get-database
                      (vla-get-activedocument
                       (vlax-get-acad-object)
    (setq ELST (entget BMENT (list (vla-get-name FOROBJ))))
    (if (assoc -3 ELST)
     (print (cadr (assoc -3 ELST)))  (print (cadar (assoc -3 ELST)))
 (prin1)
(defun C:XDL2 (/ ENAM EOBJ XDTYPE XDVALUE)
  (setq ENAM (car (entsel "\n* Select Object to Get It's Xdata *"))
EOBJ (vlax-ename->vla-object ENAM)
  (vla-getXData EOBJ "MyRoomInformation" 'XDTYPE 'XDVALUE)
  (setq xd
  (mapcar
    '(lambda (X Y)
       (cons X (variant-value Y))
    (vlax-safearray->list XDTYPE)
    (vlax-safearray->list XDVALUE)
The author is Peter Jamtgaard (I think)
Question, now how do you break apart the dotted par to read like:
Room Name  Living
Room Nunber 123
Area 211
Gary
Jürg Menzi
  • Oberegg, Switzerland
Re: XData question
« Reply #10 on: February 07, 2006, 09:48:55 AM »
(...) I thought that might be the problem, but I tried setting the codes 1001 1000 1002 and then having the first prompt put in the information at 1003, but that didn't work either. (...)
Tim, there are some restrictions with the field codes 1003 (LayerNames) and 1005 (Handles). It's not possible to add other data than (existing) LayerNames / Handles to this fields.
A computer's human touch is its unscrupulousness!
MENZI ENGINEERING GmbH
Current A2k16... A2k24 - Start R2.18
Re: XData question
« Reply #11 on: February 07, 2006, 11:22:09 AM »
Thanks everyone.  It seems like the consensus is that you only use one number per type of entry with xdata.  I can work with this.
Peter Jamtgaard
Re: XData question
« Reply #12 on: February 07, 2006, 06:33:18 PM »
One thing to remember about xdata is you cant get rid of it if you attach it to an object.
Ldata on the other hand can be deleted.
Have you ever investigate ldata?
If you are not using vba or other languages for getting the information out of the drawing you may find it easier and sometimes more versitile.
Oh and those two functions were some of my old stuff Gary, anyone is welcome to use them of course.
Peter
Chuck Gabriel
Re: XData question
« Reply #13 on: February 07, 2006, 06:37:50 PM »
Can't you get rid of it by overwriting the data with a null list.  I'm sure I've done this in VBA.
Re: XData question
« Reply #14 on: February 07, 2006, 06:42:23 PM »
Peter
I haven't really, but I have read discussions that said ldata wasn't that good by some pretty smart programmers.  If I can find the again I will post links to those conversations.
Is ldata better to use than xdata?  Opinions welcomed.
