Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
2007 Starting up slow.........
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 2007 Starting up slow......... (Read 2384 times)
VerticalMojo
Guest
on:
April 20, 2006, 03:35:32 PM »
Is my limited access to the internet making my Autocad 2007 start up slow? like 5 min..... :realmad:
Its only when I open my first dwg......
Any Ideas?
Logged
VerticalMojo
Guest
Re: 2007 Starting up slow.........
Reply #1 on:
April 20, 2006, 03:36:50 PM »
Well while Autocad was open I tried to open other dwgs and it was slow the first time, not as long as the startup but too long for me. Then I close that one and try and open it again and opens fast.
Last Edit: April 20, 2006, 03:42:36 PM by VerticalMojo
Logged
VerticalMojo
Guest
Reply #2 on:
April 20, 2006, 04:11:32 PM »
When starting up it seems to freeze at 98% when opening the acad template...... I'm guessing no one has had this problem?
Logged
Dinosaur
Guest
Reply #3 on:
April 20, 2006, 04:16:53 PM »
I found it takes a long time to start up, but not that long. Have you turned off the internet updating feature (little sattelite dish icon in botom tray)? You have to let it do its thing once and then you can disable it.
Logged
VerticalMojo
Guest
Reply #4 on:
April 20, 2006, 04:51:16 PM »
No luck Dino.....
Logged
Dinosaur
Guest
Reply #5 on:
April 20, 2006, 05:34:23 PM »
Are you starting up in the basic workspace or the new 3D modeling one? Are you loading up older lisp routines in a startup suite?
Logged
VerticalMojo
Guest
Reply #6 on:
April 20, 2006, 05:45:10 PM »
Basic workshop with no lisp routines loaded.....
Logged
Dinosaur
Guest
Reply #7 on:
April 20, 2006, 06:03:16 PM »
Do you still have the standard search paths? If you have some network paths, are you sure you have permissions set correctly in those folders? Just to confirm, do you have antivirus activated and if so, is it configured for AutoCAD?
Logged
VerticalMojo
Guest
Reply #8 on:
April 21, 2006, 11:41:03 AM »
Okay figured it out....
When I disable my local area connection Autocad boots up fine.... Auto was trying to connect to the Internet....
What we did is add the IP it needs to my allowed sites and now works like a charm!
Thanks for the help Dino... :kewl:
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
