Author Topic: Can you call a lisp routine/function from within a lisp?  (Read 3873 times)
stsevedallas
« on: April 18, 2006, 10:44:59 PM »
I have a function that I defined in another routine.
We'll call it "update"...type update at the command line in autocad to execute the routine
I want to use it, then save the drawing.
Autocad does not want to let me do the following.  Why?  How can I correct this?
(defun c:s (/)
(command "update")
(command "qsave")
(princ))
Thanks in advance.
Re: Can you call a lisp routine/function from within a lisp?
« Reply #1 on: April 18, 2006, 10:50:29 PM »
(defun c:Woot ( )
    (princ "Woot!")
(defun c:Test ( )
    (c:Woot)
command: Test <enter>
Woot!
« Reply #2 on: April 18, 2006, 11:32:47 PM »
Here is another way to handle your situation.
;;  call this from the command line
(defun c:cmdlinesave()
  (lispsave)
;; call this from your lisp
(defun lispsave ()
 (command "update")
 (command "qsave")
Slim©
  • The Dude Abides...
« Last Edit: April 19, 2006, 12:42:46 AM by Slim »
I drink beer and I know things....
stsevedallas
« Reply #4 on: April 19, 2006, 09:08:25 AM »
OK...I modified things, so...
Here is the entire lisp routine.
Can someone tell me why this error comes up?
-->Error: no function definition: ARJODATE
(defun c:s ()
  (arjodate)
  (command "qsave")
;;(defun lispsave ()
;;(command "arjodate")
;;(command "qsave")
;;(princ)
;;the arjodate function
(defun udate ( / d ct cd lin dp dn txt en e1 e ne oe)
   (setq d (rtos (getvar "cdate") 2 6))  ;get the current date and time
   (setq ct (strcat (substr d 10 2) ":" (substr d 12 2) ":" (substr d 14 2)))
   (setq cd (strcat (substr d 5 2) "/" (substr d 7 2) "/" (substr d 1 4)))
   (setq lin (getvar "LOGINNAME")
         dn (getvar "DWGNAME")
   (setq txt (strcat "LAST UPDATED: "dn " - by: " lin " on " cd " @ " ct))
   (setq en (ssname e1l 0))
   (setq e1 (entnext en))   ;get the attribute
   (setq ne (cons 1 txt))   ;create the new attribute assoc list
   (setq e (entget e1))     ;get the attribute name for the attribute
   (setq oe (assoc 1 e))    ;get the attribute assoc list
   (setq e (subst ne oe e)) ;substitute new list for old list
           (entmod e)       ;modify the attribute
  (entupd e1)               ;update the block
   (princ "\n.......... arjodate block has been updated ..............")
(defun C:arjodate ( / e1l)
;  (grtext -1 "      LISP ROUTINE BY AJ  ")
  (if (= (tblsearch "BLOCK" "arjodate") nil)
    (prompt "\n...... arjodate block NOT FOUND in current dwg database ....")
    (prompt "\nPick block insertion point: ")
    (command "INSERT" "arjodate" "1.25,1,0" "2" "" "")
   (setq e1l (ssget "x" '((0 . "INSERT")(2 . "arjodate"))));FIND THE BLOCK
 (if e1l
   (udate)
     (princ ".......... arjodate block needs to be inserted ..............")
     (setq e1l (ssget "L"))
     (udate)
;........end of file
<code tags added>
« Last Edit: April 19, 2006, 11:38:08 AM by CAB »
Slim©
« Reply #5 on: April 19, 2006, 09:35:01 AM »
(defun c:s ()
(c:arjodate)
  (command "qsave")
;;(command "qsave")
;;(princ)
 (if e1l
   (udate)
     (udate)
Try that...  :-)
« Reply #6 on: April 19, 2006, 09:36:03 AM »
Short answer --
Since it's defined thusly --
(defun c:Arjodate ( / e1l) ...)
She gotta be called same --
(defun c:s ()
    (c:Arjodate)
    (command "qsave")
Edit: What Slim said!
« Last Edit: April 19, 2006, 09:39:35 AM by MP »
stsevedallas
« Reply #7 on: April 19, 2006, 11:34:18 AM »
Got it.
Thanks all.
