Author Topic: usage of global variables  (Read 2888 times)
FengK
« on: March 24, 2006, 04:47:14 AM »
Hello,
I used to think that it is not a good idea to use global variables in lisp codes and variables should be local to their corresponding commands.  Now I've completely changed my mind.  I use global variables a lot.  But to avoid making a big mess, all these global variables are named "glb::cmd_*", where cmd is the name of the command and "*" can be anything.  The primary reason for me to use global variables is to make user input a little easier.  If a user repeatly uses a command, his previous input can be used as the default value for later ones.  Or in some cases, user will not need to be asked for that input.  I have a command to clean these global variables when necessary.
(defun C:00 (/ strName)
  (prompt "\nScanning for variables...")
  (foreach sym (atoms-family 0)
    (setq strName (strcase (vl-symbol-name sym)))
    (if   (wcmatch strName "GLB::*")
      (set sym nil)
  (prompt " Done.")
I'm thinking of triggering this when double-click on an empty spot occurs.
If a variable needs to be shared among open drawings, I use vl-bb-ref and vl-bb-set.
What's your thought?  Thank you.
Kelie
Jürg Menzi
  • Oberegg, Switzerland
Re: usage of global variables
« Reply #1 on: March 24, 2006, 04:58:06 AM »
Kelie
Using global vars is a necessary thing in some code. My own rules:
- Default values for user prompts -> global vars
- Default values relating to drawing -> dictionary
- Default values relating to application -> registry (or ini file)
MENZI ENGINEERING GmbH
CADmium
« Reply #2 on: March 24, 2006, 08:30:56 AM »
Kelie
..and  Default values  for one ACAD-Session ..blackboard namespace -> vl-bb-ref / vl-bb-set functions, but i also prefer registry for this implementation
"Bei 99% aller Probleme ist die umfassende Beschreibung des Problems bereits mehr als die Hälfte der Lösung desselben."
GDF
« Reply #3 on: March 24, 2006, 10:02:32 AM »
Kelie
I do something similar, but need to do more dictionaries. My globals or way overkill, but I'm still learning.
Gary
« Last Edit: March 24, 2006, 10:12:21 AM by Gary Fowler »
FengK
« Reply #4 on: March 25, 2006, 03:31:15 AM »
Thanks Jürg.  I think I need to take a look at dictionary and registry now.
Jürg Menzi
« Reply #5 on: March 25, 2006, 05:11:56 AM »
Welcome... :-)
You may check CADmium's recommendation also:
