Author Topic: 1" J-Channel Lisp Routine  (Read 6461 times)
One Shot
« on: March 09, 2006, 04:52:53 PM »
I am looking for a lisp routine to create a 1" J-Channel. It should have the option to leave it open or closed. A close situation would be starting and working around the window and closing where you started. The open situation would be started at one location and end at another. It should work with radiuses and multiple point locations. Would like the outer line be magenta and the inside line be green. the linetype should be by block and layer should be layer 0. I would like to have the block be named and sent to a specific folder that I can edit the location in the lisp. The block name would read like the following:
JC-(WIDTH x HEIGHT).dwg
if you have any questions, please don't hesitate to ask.
Thank you,
Brad
Bob Wahr
Re: 1" J-Channel Lisp Routine
« Reply #1 on: March 09, 2006, 04:56:16 PM »
How much are you looking to spend?
« Reply #2 on: March 09, 2006, 05:07:18 PM »
And most customisers would need a little better specification.
One Shot
« Reply #3 on: March 09, 2006, 06:00:09 PM »
I am welling to pay in appreciation and gratitude for your time and experience!  I hope that you can agree to my payment method.
Thank you,
Brad
Serge J. Gianolla
« Reply #4 on: March 09, 2006, 06:22:16 PM »
Sure... I'll get back to you. 1st, let me check if; when I have to pay the rent or a bill, they accept appreciation and gratitude. :evil:
Serge J. Gianolla
« Reply #5 on: March 09, 2006, 06:27:41 PM »
Hopefully One Shot, you have a sense of humour.
It is certainly not my intention to be on the wrong side of a former Marine. :laugh:
« Reply #6 on: March 09, 2006, 06:47:12 PM »
Look at his sig,
Semper Fi!!!
Once a Marine, Always a Marine!
AutoCAD / ADT 2005
You might be in trouble still.   :-)
Serge J. Gianolla
« Reply #7 on: March 09, 2006, 06:52:03 PM »
Alea Jacta Est!
« Last Edit: March 09, 2006, 07:14:10 PM by Serge J. Gianolla »
« Reply #8 on: March 09, 2006, 06:56:15 PM »
Ex Marine or not, it's a little tiring that almost all of One Shot's posts include the words "I want" or "I need".
Bob Wahr
« Reply #9 on: March 09, 2006, 06:56:57 PM »
The really sad thing is that someone probably will.  If you were trying to do it yourself and asking for help, it would be one thing, if you were in a bind but usually tried to do it/learn, it would be another but you don't.  You post looking for someone to write custom applications for you for free and I take exception to that.
LE
« Reply #10 on: March 09, 2006, 07:12:36 PM »
I will mention the following:
Not related at all... by answering similar comments like the previous ones, I noticed that I have been putting apart.... that's the impression I got... to bad, so in the future I not even going to make any comment referring to any person at all, good or bad... I will simple will be focus on programming.
Have fun.
One Shot
« Reply #11 on: March 09, 2006, 07:22:14 PM »
Gentlemen,
I am sorry if I ask a lot of you guys.  I hope that I did not affend you guys.  I have been trying to learn it on when I can. The items that I asked are at a spur of the moment.  The reason I asked is that it might take me a few days to get one done while it may take you guys 10 to 15 minutes to do.  I promise that I will work hard on learning lisp in the future and I will ask you guys as a last resort.
Thank you,
Brad
« Reply #12 on: March 09, 2006, 07:22:45 PM »
I asked for a better specification.
The question was ignored.... but I'm getting used to that (NOT)
Serge J. Gianolla
« Reply #13 on: March 09, 2006, 07:23:04 PM »
Luis, the problem is not so much in what is said, but more in how it is said. When it is obvious that one is mucking around it takes the venom out of it. I have to admit though that it is not always easy to put across with written words. In verbal comments, face to face situations there are the mannerism + the other non-verbal clues associated with discussion, no such luck when posting comments, even the emoticons are not enough!
Bob Wahr
« Reply #14 on: March 09, 2006, 07:27:22 PM »
Did I come off as mucking around?  If so, it was purely unintentional I assure you.
