Author Topic: Add blocks to Tool Palettes  (Read 7896 times)
One Shot
« on: February 27, 2006, 03:55:15 PM »
How do you add blocks to Tool Palettes?
Thank you,
Brad
David Hall
  • Automatic Duh Generator
Re: Add blocks to Tool Palettes
« Reply #1 on: February 27, 2006, 03:57:54 PM »
insert into a source dwg, save, drag and drop on pallet
One Shot
« Reply #2 on: February 27, 2006, 04:05:30 PM »
I have tried to take a dwg file and drag and drop but there is no image showing in the Tool Palette.
Thank you,
Brad
David Hall
« Reply #3 on: February 27, 2006, 04:20:13 PM »
what i do is open a "symbol" file from my network.  Insert the block there.  Save that dwg. drag the block i just inserted onto the pallet.  Does that work?
David Hall
« Reply #4 on: February 27, 2006, 04:20:51 PM »
the network file is just so every one here uses same files.  It could be local to your machine.
One Shot
« Reply #5 on: February 27, 2006, 04:36:19 PM »
I still cannot see an image.
thank you,
Brad
MickD
« Reply #6 on: February 27, 2006, 07:53:32 PM »
Try opening the design centre, go to the drawing that contains the block def and drag it from the design centre to your palette. Drag and drop is the easiest way to add items to your palettes, experiment and you'll get it to work ;)
hth.
- John Carmack
"Everything that is possible demands to exist"
- Gottfried Wilhelm von Leibniz
CottageCGirl
« Reply #7 on: March 01, 2006, 08:53:22 AM »
I spent some time trying to put my blocks onto pallets, but since my blocks are made up of many small items, you could not tell the difference by the image on the pallet, so we have continued to use the custom pull down menus, has there been any headway on customizing the images?
ryandk
« Reply #8 on: March 01, 2006, 12:10:04 PM »
You can create any image you would like and use it as the icon.  Select the tool, right-click, properties.  There will be an image on that dialog box.  Right-click, just browse and select.
