Thanks Gary, i have no doubt that it's he best forum
![Smiley :)](http://www.theswamp.org/Smileys/black/smiley.gif)
I've been looking around for a few days and my brain hurts lol.
Well, your description makes sense, and that's what I ment by ObjectDBX, i just haven't dealt with it enough to memorize that it's not obd (obdII sensors from the cars that I gets me confused), but ObjectDBX.
The list you posted is also similar to what I get, i do the same operation, but like I said, in a very messy way. I rely on a batch program to shuffle through the drawings, then I use a windows cmd to combine all txt files into one file and open it in excel and go from there.
I guess my question is more for that code in particular. If you have a minute to answer these basic questions, this will be allot more clear for me.
(defun C:CSI (/ indexlist file)
(getfolder)
(ARCH:CreateIndex2436TBA)
(if (= indexlist nil)(ARCH:CreateIndex2436TAG))
(setq file (open "C:\\Temp\\SheetIndex.txt" "w"))
(repeat
(length indexlist)
(setq a (car indexlist) indexlist (cdr indexlist))
(write-line (strcat (car a) "\t" (cdr a)) file)
(close file)
(command ".shell" "notepad C:\\Temp\\SheetIndex.txt")
Code above you first call the "getfolder", which is pretty straight forward (although for some reason when I run it the "folderlist" comes back as nill, that is when i break right at the end of that function.
Then you call "getindex" through the ARCH:*** which is basically sorting of the document that you get.
Am I somewhere ok so far?
Now, this GETINDEX just does not make much sense to me on how it works.
Could you give me a brief description before I make a fool out of myself? Step by step would be asking for too much, but if it won't take long, THANK YOU!
But thanks in either way!
Viktor.
