Author Topic: TryParse for NET 2.0  (Read 3549 times)
« on: February 05, 2006, 09:01:32 PM »
If you're a little tired of wrapping for Exceptions when using the Type.Parse(..) with NET 1.x ,
have a look at Type.TryParse(..) with NET 2.0 .. very nice I think ..
        static void ParseStuff()
            string xString = "5";
            int xInt;
            bool result = int.TryParse(xString, out xInt);
« Last Edit: February 05, 2006, 09:09:26 PM by Kerry Brown »
kdub in one timeline.
--> Donate to theSwamp<-
