Author Topic: autolisp exercise  (Read 8852 times)
ELOQUINTET
autolisp exercise
« on: January 09, 2006, 01:24:03 PM »
i have some free time for a couple days so i would like to convert a macro we have into lisp. the macro creates a border layer. then creates a viewport. it captures then last modelspace view then centers that view inside the viewport with the scale set to 1:2. i would like to be able to check to see if the layer is present and if it isn't create it. i just feel it's getting to complicated for a macro and would be much cleaner as a lisp. besides i need the excercise. so if anyone would like to help me out i'd really appreciate it. i don't want it written but some big hints on how to structure it would be nice.
^C^C_-LAYER;M;BORDER;C;251;;P;N;;;^C^C_MVIEW;\\;^C^C_CHANGE;L;;P;C;BYLAYER;LA;BORDER;;_.MSPACE;Z;O;L;;Z;S;1/2XP;.PSPACE;^C^C_LAYERP; ^M;
Crank
Re: autolisp exercise
« Reply #1 on: January 09, 2006, 01:36:11 PM »
Just curious... Why so much cancels in one macro?
ELOQUINTET
« Reply #2 on: January 09, 2006, 01:44:55 PM »
yeah the guy who wrote the macro was not very experienced and was under the impression everything had to be cancelled
« Reply #3 on: January 09, 2006, 01:48:18 PM »
Which way you want to go?
Lisp/VLisp?
ActiveX?
ELOQUINTET
« Reply #4 on: January 09, 2006, 01:53:46 PM »
mmm...i think lisp or vlisp. i would say lisp being that it is the only thing i have limited knowledge of. i am very much a beginner so please be patient with me. i am looking through some lisp i have already trying to find an example of how to check for a given layer and if it's not present create it and set current
deegeecees
« Reply #5 on: January 09, 2006, 01:56:36 PM »
Did I write that?
 :-D
« Reply #6 on: January 09, 2006, 02:03:04 PM »
In that case, you want to look at the table funtions.  If you want to get complicated then you can use "entmake" for the layer (I think, but I don't use entmake all that often) if it doesn't exist, or just use the layer command to add it.
This should get you started.
« Reply #7 on: January 09, 2006, 02:06:41 PM »
I'd start by framing in the functional outline in comments. I just bashed this out quick to give you an idea --
(defun c:foo ( )
    ;;  save the current layer
    ;;  make the border layer if it doesn't exist
    ;;  set the colors of the border layer
    ;;  make the border layer non printable
    ;;  set the current layer to the border layer
    ;;  set tilemode to 1
    ;;  switch to paperspace
    ;;  make a viewport, record it's viewport id
    ;;  switch to modelspace
    ;;  make the viewport we just made active (use the viewport id)
    ;;  zoom all, then 1/2 xp
    ;;  change back to paperspace
    ;;  set the active layer back to the one we started with
Crank
« Reply #8 on: January 09, 2006, 02:46:36 PM »
I think the TILEMODE must be 0.
Why not follow the macro?
(defun c:foo ()
(if (tblsearch "LAYER" "BORDER")
(setvar "CLAYER" "BORDER")
(vl-cmdf ".layer" "m" "BORDER" "C" "251" "" "P" "N" "" "")
(setvar "TILEMODE" 0); be sure that you start in a layout
(command ".mview" (getpoint "\nSelect rectangle of viewport...")(getcorner "to..." (getvar "LASTPOINT")))
(vl-cmdf ".chprop" "L" "" "c" "bylayer" "")
(vl-cmdf ".mspace")
(vl-cmdf ".zoom" "all")
(vl-cmdf ".zoom" ".5xp")
(vl-cmdf ".pspace")
(vl-cmdf ".layerp")
ELOQUINTET
« Reply #9 on: January 09, 2006, 03:28:03 PM »
foo that worked if i only had 1 object in my drawing which is never the case. i modified it to work like the macro does and seem to have gotten it. i have printed out the tblsearch and vl-cmdf from help to look at as well. here's what i got:
thanks alot for the help :)
(defun c:foo ()
(vl-cmdf ".chprop" "L" "" "c" "251" "")
(vl-cmdf ".mspace")
(vl-cmdf ".zoom" "O" "L" "")
(vl-cmdf ".zoom" "S" ".5XP")
(vl-cmdf ".pspace")
(vl-cmdf ".layerp")
« Reply #10 on: January 09, 2006, 04:20:55 PM »
And what happens when the layer exist & is frozen? :evil:
« Reply #11 on: January 09, 2006, 04:27:34 PM »
partypooper !
 :-P
deegeecees
« Reply #12 on: January 09, 2006, 04:31:13 PM »
(if (= (logand 1 (cdr (assoc 70 ts))) 1)
(thawthething)
ELOQUINTET
« Reply #13 on: January 09, 2006, 04:35:04 PM »
o god here we go leave it to cab to throw a monkey wrench into the bicycle tire.
« Reply #14 on: January 09, 2006, 04:47:18 PM »
I was thinking more like this: 8-)
(defun c:foo (/ lyr p1 p2)
  (setq lyr "BORDER")
  (if (tblsearch "LAYER" lyr)
    (vl-cmdf "._Layer" "_Thaw" lyr "_On" lyr "_UnLock" lyr "_Set" lyr "")
    (vl-cmdf ".layer" "m" lyr "C" "251" "" "P" "N" "" "")
  (setvar "TILEMODE" 0) ; be sure that you start in a layout
  (if (and
        (setq p1 (getpoint "\nSelect rectangle of viewport..."))
        (setq p2 (getcorner p1 "to..."))
      (vl-cmdf ".mview" p1 p2)
      (vl-cmdf ".mspace")
      (vl-cmdf ".pspace")
      (vl-cmdf ".layerp")
