Author Topic: AU 2005 code - Part 7 "Digging into the Database"  (Read 4756 times)
Bobby C. Jones
  • Cry havoc and let loose the dogs of war.
« on: December 28, 2005, 02:59:28 PM »
Get out yer' shovels and start diggin'
This is the basics of the Database.  Nothing new to most of you.
using System;
namespace AU2005.AcadApi
//Pages 13 to 17
public class DatabaseExamples
//Page14
//Digging into the database, symbol tables, and ObjectId's
[CommandMethod("ShowAllLayers")]
public void ShowAllLayers()
//Get the current editor object
Editor currentEditor = AcadApp.DocumentManager.MdiActiveDocument.Editor;
//Get the current database object
Database activeDatabase = currentEditor.Document.Database;
//Start a transaction
using(Transaction trans = activeDatabase.TransactionManager.StartTransaction())
//Open the layer table
ObjectId layertableId = activeDatabase.LayerTableId;
LayerTable layers = (LayerTable)trans.GetObject(layertableId,OpenMode.ForRead);
//Iterate the layerId's in the layer table
foreach (ObjectId layerId in layers)
//Open the layer for reading
LayerTableRecord layer = (LayerTableRecord)trans.GetObject(layerId, OpenMode.ForRead);
//Print the layer name to the command line
currentEditor.WriteMessage("\n" + layer.Name);
//Page 15
//Accessing databases in the editor and from a file
[CommandMethod("InsertBlock")]
public void InsertBlock()
string sourceFileName = @"C:\OftenUsedBlock.dwg";
string newBlockName = "OftenUsedBlock";
try
using(Database sourceDatabase = GetDatabaseFromFile(sourceFileName))
//Insert the entities from modelspace of the sourceDatabase into
//a new block table record of the working database
HostApplicationServices.WorkingDatabase.Insert(newBlockName, sourceDatabase, false);
catch (System.Exception e)
Application.ShowAlertDialog(e.Message);
public Database GetDatabaseFromFile(string fileName)
Database databaseFromFile = new Database(false, true);
databaseFromFile.ReadDwgFile(fileName, System.IO.FileShare.None, false, null);
return databaseFromFile;
//Page 15 lists the steps, Page 17 lists the code
//Adding objects to a database
//The six steps revealed!
[CommandMethod("CreateCircle")]
public void DrawCircle ()
//Step one - Start a transaction
using (Transaction trans = StartActiveDatabaseTransaction())
//Step two - Create the new object
Circle newCircle = CreateCircle();
//Step three - Open the symbol table
BlockTableRecord modelSpace = OpenActiveModelSpaceForWrite(trans);
//Step four - Append the object to the symbol table
modelSpace.AppendEntity(newCircle);
//Step five - Inform the transactionmanager of the new object
trans.TransactionManager.AddNewlyCreatedDBObject(newCircle, true);
//Step six - Commit the transaction
trans.Commit();
private Transaction StartActiveDatabaseTransaction()
return HostApplicationServices.WorkingDatabase.TransactionManager.StartTransaction();
private Circle CreateCircle()
Point3d centerPoint = new Point3d(0, 0, 0);
Vector3d normal = new Vector3d(0, 0, 1);
double radius = 4.5;
return new Circle(centerPoint, normal, radius);
private BlockTableRecord OpenActiveModelSpaceForWrite(Transaction trans)
return (BlockTableRecord)trans.GetObject(GetActiveModelSpaceId(), OpenMode.ForWrite);
private ObjectId GetActiveModelSpaceId ()
BlockTable bt = (BlockTable)trans.GetObject(HostApplicationServices.WorkingDatabase.BlockTableId, OpenMode.ForRead);
return (ObjectId) bt[BlockTableRecord.ModelSpace];
//Page 16
//Adding non graphic objects
//Variations of the six steps
public static ObjectId CreateLayer(string layerName, Database targetDatabase)
using (Transaction trans =targetDatabase.TransactionManager.StartTransaction())
ObjectId layerTableId = targetDatabase.LayerTableId;
//This table has only been opened for reading
LayerTable layers = (LayerTable)trans.GetObject(layerTableId, OpenMode.ForRead);
if (layers.Has(layerName))
return layers[layerName];
else
LayerTableRecord newLayer = new LayerTableRecord();
newLayer.Name = layerName;
//Step three - Open the symbol table for writing
layers.UpgradeOpen();
layers.Add(newLayer);
trans.TransactionManager.AddNewlyCreatedDBObject(newLayer, true);
trans.Commit();
return newLayer.ObjectId;
[CommandMethod("CreateLayer")]
public void CreateLayer()
string newLayerName = "AU2005";
CreateLayer(newLayerName, HostApplicationServices.WorkingDatabase);
Bobby C. Jones
TR
Re: AU 2005 code - Part 7 "Digging into the Database"
« Reply #1 on: December 29, 2005, 11:42:31 AM »
Bobby:
I have found that in order for the insert block command to work on multiple drawings in a session you need to close the file in this function. At least this is the case for me in AutoCAD 2005.
databaseFromFile.CloseInput(true);
Thanks for all the awesome examples and keep em coming. :)
Bobby C. Jones
« Reply #2 on: December 29, 2005, 12:12:15 PM »
Bobby:
Thanks for the heads up Tim!
Bobby C. Jones
TR
« Reply #3 on: December 29, 2005, 01:15:16 PM »
No problem. Just out of curiosity, does your code work with multiple drawings in a single session in 2006? For example running InsertBlock on Drawing1.dwg, creating a new drawing and then running InsertBlock on Drawing2.dwg.
« Reply #4 on: January 10, 2006, 03:16:51 PM »
Missed this Tim
command handlers run in the application context when they are registered with "CommandFlags.Session"
so you'd need this sort of thing to register the command ;
[CommandMethod("MySuperDuperCommand",CommandFlags.Session)]
kdub in one timeline.
--> Donate to theSwamp<-
