Author Topic: Xdata....again.  (Read 9563 times)
Jeff_M
  • C3D user & customizer
Re: Xdata....again.
« Reply #15 on: December 02, 2005, 05:42:43 PM »
You load the (defun listtovaraintarray .....) just like you do any other function......
It is then called by the lines:
(setq codes (listtovariantarray (reverse newcodes) vlax-vbInteger)
      vals (listtovariantarray (reverse newvals) vlax-vbvariant))
Andrea
Re: Xdata....again.
« Reply #16 on: December 07, 2005, 03:22:12 PM »
I'm sorry Jeff, but not sure if I really understand.
the listtovaraintarray is somthing allready exist in AutoCAD ?
or I need to create one ?   :|
Keep smile...
Re: Xdata....again.
« Reply #17 on: December 07, 2005, 03:23:19 PM »
Andrea, go back and read post #10 in this thread <by Jeff>.
added:
actually, it's Reply #10 instead
« Last Edit: December 07, 2005, 03:29:50 PM by Kerry Brown »
