Author Topic: Once upon a time in a missing monitor....  (Read 2612 times)
« on: February 04, 2004, 05:00:45 PM »
Here's the situation.......machine used to have 2 monitors. Now it only has one monitor but the AutoCAD Properties Dialogue location was saved on the other monitor. How do I change the location to the new monitor when I can't even see it? I checked the registry a bit but didn't find much.
AutoCAD 2002
Thanks,
Ron
daron
« Reply #1 on: February 04, 2004, 05:04:09 PM »
You need to put the other monitor back on and keep it on. But if you can't keep it, you still need to put it back on so you can move the dialog. I'd look into keeping it (the monitor) up for a couple of days to move everything to one side. Why are you only using one monitor now?
