Author Topic: Update Block Attributes  (Read 7973 times)
Draftek
« on: November 10, 2005, 05:05:37 PM »
I need to update a block Insert's attributes from a selection set of dimensions.
Have this little test method that accepts the matching tag property and the textstring value.
It works okay, except the block reference does not get updated....
Any Ideas why the transaction.Commit() is not doing anything?
private void ModifyBlockAtt(string dimNo, string sValue)
// already have db and ed defined
Transaction tr;
TypedValue[] filterlist;
Autodesk.AutoCAD.EditorInput.SelectionFilter filter;
Autodesk.AutoCAD.EditorInput.PromptSelectionResult selRes;
Autodesk.AutoCAD.EditorInput.SelectionSet oSS = null;
using(tr = db.TransactionManager.StartTransaction())
filterlist = new TypedValue[2];
filterlist[0] = new TypedValue(0, "INSERT");
filterlist[1] = new TypedValue(2, "CrimperDataInputTable");
filter = new SelectionFilter(filterlist);
selRes = ed.SelectAll(filter);
if (selRes.Status != Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
ed.WriteMessage("\nNo Table Block in the drawing ");
return;
oSS = selRes.Value;
BlockReference oEnt;
oEnt = (BlockReference)tr.GetObject(oSS[0].ObjectId, OpenMode.ForRead);
for (int i = 0; i < oEnt.AttributeCollection.Count; i++)
ObjectId id = oEnt.AttributeCollection[i];
AttributeReference aRef = (AttributeReference)tr.GetObject(id, OpenMode.ForWrite);
if (aRef.Tag == dimNo)
aRef.TextString = sValue;
tr.Commit();
return;
Re: Update Block Attributes
« Reply #1 on: November 10, 2005, 05:17:13 PM »
You should put your tr.Commit() as the last thing before returning from your method. The transaction wraps up all of your work in one lot and completes  with Commit(). You may be finalising your trans'n too early ;)
See if that works.
- John Carmack
- J.R.R. Tolkien
Draftek
« Reply #2 on: November 10, 2005, 05:31:44 PM »
Thanks, I'll give that a try.
« Reply #3 on: November 10, 2005, 05:37:46 PM »
Actually, include it in your using(tr = ....  code block, after you've finished bd Mods, I believe ...
Draftek
« Reply #4 on: November 10, 2005, 05:40:42 PM »
HA!
Thanks to both of you, I had a transaction in the calling method that I had not Committed.
Once again, proving that I'm nothing more than a hack!
Please remember this question, because in about a month or two, I'll ask the exact same thing again.
seriously.
« Reply #5 on: November 10, 2005, 05:48:20 PM »
Thanks Kerry, that is what I meant too, just wasn't clear.. :oops:
I've actually had mixed results with using a 'using' with transactions so now I just use this as a rule and I've had no problems since
public void SomeFoo()
Transaction tr = db.TransactionManager.StartTransaction();
try
//do stuff here!
tr.Commit();
catch
ed.WriteMessage("KaBoom!..");
tr.Dispose();
- John Carmack
- J.R.R. Tolkien
« Reply #6 on: November 10, 2005, 05:58:08 PM »
Hi Mick,
Yes, that is suggested by some commentators,
but, according to the Spec's, the 'using' mechanism will automatically clean up, < edit : even in the event of an unhandled exception { need to qualify this statement ! }. >
One issue that I see is that VB.Net can not use 'using' so there may be some semantic difficulties when 'people' try to translate code from one language to another.
« Last Edit: November 11, 2005, 07:27:38 PM by Kerry Brown »
Bobby C. Jones
« Reply #7 on: November 11, 2005, 11:10:01 AM »
What kind of mixed results are you seeing Mick?
Bobby C. Jones
« Reply #8 on: November 11, 2005, 05:17:11 PM »
I can't remember exactly Bobby (it was a while ago now), but I think it was when calling methods or passing objects such as the db inside/outside of the using statement.
My lack of experience with the language probably had more to do with it than anything else, but once I started using it the 'standard' way (as above) I've had no trouble since.
- John Carmack
- J.R.R. Tolkien
« Reply #9 on: November 11, 2005, 05:19:18 PM »
...heh, just thinking about it, I was probably doing something similar to Draftek with the Commit() method  :laugh:
- John Carmack
- J.R.R. Tolkien
