Author Topic: rotation of text  (Read 3538 times)
David Hall
  • Automatic Duh Generator
rotation of text
« on: November 02, 2005, 01:34:21 PM »
I cant get this to work.  What im trying to do is fix a drawing a consultant sent me.  his text is not all at 0 or 90 degrees.  I want to check each piece of dtext and mtext for rotation, and fix the non-standard ones.  here is my code
Option Explicit
Public Sub FIX_ROTATION()
    Dim objSelected As Object
    Dim objTxt As AcadText
    Dim objMTxt As AcadMText
    Dim objSelSet As AcadSelectionSet
    On Error GoTo ErrControl
    Dim N As Integer
    Dim pi
    pi = 4 * Atn(1)
    If ThisDrawing.SelectionSets.Count > 0 Then
        For N = 0 To ThisDrawing.SelectionSets.Count - 1
            If ThisDrawing.SelectionSets.Item(N).Name = "FIXTEXT" Then
                ThisDrawing.SelectionSets("FIXTEXT").Delete
            End If
        Next N
    End If
    Set objSelSet = ThisDrawing.SelectionSets.Add("FIXTEXT")
    objSelSet.SelectOnScreen
    'objSelSet.Select acSelectionSetAll
    For Each objSelected In objSelSet
        If TypeOf objSelected Is AcadText Then
            Set objTxt = objSelected
            Select Case objTxt.Rotation
                Case 0:
                    objTxt.Rotation = 0
                Case 90:
                    objTxt.Rotation = (pi / 2)
                Case objTxt.Rotation < (pi / 2)         <---- here is the problem.  Im trying to find text w/ > 0 but < 75 degrees
                    objTxt.Rotation = 0
                Case Else
            End Select
        End If
    Next
    '        For Each objSelected In objSelSet
    '        If TypeOf objSelected Is AcadText Then
    '            Set objTxt = objSelected
    '            If objTxt.Rotation > 0 And objTxt.Rotation < 75 Then
    '                objTxt.Rotation = 0
    '            Else: objTxt.Rotation = (pi / 2)
    '            End If
    '        End If
    '    Next
    '        If TypeOf objSelected Is AcadMText Then
    '            Set objMTxt = objSelected
    '            If objMTxt.Rotation > 0 And objMTxt.Rotation < 75 Then
    '                objMTxt.Rotation = 0
    '            Else: objMTxt.Rotation = 90
    '            End If
    '        End If
    '    Next
    ThisDrawing.SelectionSets.Item("FIXTEXT").Delete
    ThisDrawing.Application.Update
Exit_Here:
    Exit Sub
ErrControl:
    MsgBox Err.Description
I started using IF statements, but didn't want to nest 4 levels deep
Bob Wahr
Re: rotation of text
« Reply #1 on: November 02, 2005, 01:52:06 PM »
Don't have time to make it pretty right now, maybe at lunch but what about this
Option Explicit
    Dim dblRotDec As Double
    Dim dblRotRad As Double
    Dim N As Integer
    Dim pi
    pi = 4 * Atn(1)
            End If
        Next N
    End If
            dblRotRad = objTxt.Rotation
            dblRotDec = (dblRotRad * 180) / pi
            If dblRotDec > 180 Then
              dblRotDec = dblRotDec - 180
            End If
            If dblRotDec > 45 And dblRotDec < 135 Then
              dblRotRad = (90 * pi) / 180
            Else
              dblRotRad = 0
            End If
            objTxt.Rotation = dblRotRad
        End If
    Next
Exit_Here:
    Exit Sub
ErrControl:
I would also filter the selection set so only text is selectable, then you could get rid of the "if typeof" test
David Hall
« Reply #2 on: November 02, 2005, 02:17:31 PM »
that works well.  Thanks.  I couldn't get my head wrapped aroung the nested ifs today
David Hall
« Reply #3 on: November 02, 2005, 02:18:18 PM »
that was next on the list.  thanks
Bob Wahr
« Reply #4 on: November 02, 2005, 02:32:20 PM »
Still not very secksie but
Option Explicit
    Dim dblRot As Double
    Dim intGrp(0 To 3) As Integer
    Dim varDat(0 To 3) As Variant
        For Each objSelSet In ThisDrawing.SelectionSets
            If objSelSet.Name = "FIXTEXT" Then
                objSelSet.Delete
                Exit For
            End If
        Next objSelSet
    End If
    intGrp(0) = -4: intGrp(1) = 0: intGrp(2) = 0: intGrp(3) = -4
    varDat(0) = "<or": varDat(1) = "TEXT": varDat(2) = "MTEXT": varDat(3) = "or>"
    objSelSet.SelectOnScreen intGrp, varDat
            dblRot = objTxt.Rotation
            objTxt.Rotation = Angulator(dblRot)
        Else
            dblRot = objMTxt.Rotation
            objMTxt.Rotation = Angulator(dblRot)
        End If
    Next
Exit_Here:
    Exit Sub
ErrControl:
Function Angulator(dblRotRad As Double) As Double
    Dim PI As Double
    PI = 4 * Atn(1)
    dblRotDec = (dblRotRad * 180) / PI
    End If
      Angulator = (90 * PI) / 180
    Else
      Angulator = 0
    End If
End Function
Bob Wahr
« Reply #5 on: November 02, 2005, 02:33:59 PM »
Not a problem.
