Author Topic: (Challenge) Give me your lunch money!  (Read 6660 times)
« on: January 30, 2004, 11:48:16 AM »
Do you want to see what I'm doing?! --Of course you do.-- Well its to bad that we cant see what eachother is doing cause I'm doing something cool. I want to share data between AutoCAD and Microstation. --why? cause its cool!-- Now granted, this could get a bit messy. But I dont think we are orginized enough to pass major amounts of data back and forth yet so all I want is little stuff like a couple of lines and layers. Up for it?
Read this article and then come back here and post when you get it working.
Tag, you're it
daron
« Reply #1 on: January 30, 2004, 12:00:39 PM »
So, what you're saying is you want to use xml to create info, then use vba to control the info, cross-platformatically? <layer id="John">John</layer>
Contain that in a an xml root structure and you can use the layer#John to get the info. If you use class="John" you can use layer.John to get the info. That's at least how you'd get css to set style to it. Guess I'd have to know a bit more about vba to know how to do it otherwise.
« Reply #2 on: January 30, 2004, 12:04:08 PM »
Yeah essentaily. I want to share 'line endpoints', 'Layer info' ...stuff like that.
Nah, its easy. I took Randalls code blocks and modified them to work with Microstation already. You can do it Daron. (Your better at VBA then me?!)
daron
« Reply #3 on: January 30, 2004, 12:26:12 PM »
Not yet. I've switched gears to web development, to get mine off the ground. I'm still trying to get everything worked out there.
